Why are there more than one slot that look to be winch cable routing slot but a winch can only be mounted in the "main" area?
The winch needs to be mounted in the cradle due to the forces involved. There is only one place for the cable to go through the bar to be wound correctly on the winch spool and avoid binding or sharp angles.
There are two spot the cable could go through the bar:
1) Bottom hole for a underwound winch.
2) Top hole for a overwound winch.
The winch sits in the same spot in either case....... give you a choice of underwound or overwound.
