New Air conditioner
Charlotte NC
After my window AC unit broke, I was quick to crack it open and see what was inside. I discovered that the cooling method was very simple. I was thinking of dissambling one of these and rigging it up in my cruiser for those HOT days. Has anybody ever seen this attempted or anything like it? I am curious, because it looks like it would be so easy to do.
ummmm yes..........some hillbilly used a inverter to power one in a mini truck, he "installed" the AC unit by cutting a hole in the bed and the cab and stuffin it in........
Y'all got any pics of that? Way cool...I have an old 76 chev we did a bunch of silly redneck stuff to. We didn't think of that! Time to try it out!!
Seriously tho, go for it! I wonder what you'l run into in the way of 110 power vs 12V? A converter like Pimp said.
at the very least, get a 12v motor.....
:rolleyes:
good luck!
be sure to take a lot of pics so that you can have brian put this in the tech links when you are done!!!
:beer:
-Steve
be better off installing an junked AC unit from another vehicle.
remember that home units use different freon types. and to charge these one you would most probably need an EPA license to buy the freon you would need.
Noble idea. definetly fix into the "red neck" car AC...
You're going to need a monster inverter - if it's e.g. 20 amps at 120 volts, it's 200 at 12 volts for teh same power. Then multiply by two so you can start the motor turning. That 5kw for 20 amps.
Exactly.
The cost of the inverter that you would need to run it would be more than the cost of having someone install an aftermarket AC system.
