I just picked up a 93 FZJ80 from a friend through a trade deal. Its a slightly neglected high mileage truck that I plan on turning into a weekend warrior, expo type rig. The PO had the headgasket and timing chain done about 30k ago. The truck seems to run well under throttle but has an idle issue. I did notice that the EGR modulator ( I think) had the side blown out of it (melted looking) and was missing some vacuum lines. Im going to disable/remove the EGR this coming weekend and possibly the PAIR. Im not a fan of how low the cats and huge muffler hang down so I figured I could get rid of the cats and move the O2's to the manifold. As far as the idle issue, it idles up when started cold then as it drops it starts to get rough. It drops to about 500 rpm and just doesn't sound good and vibrates the trucks. It seems to get a little worse with the AC running. Also, while driving with the AC, there is a slight change in the rpms up and down while maintaining throttle position. It doesn't seem to do this with the AC off. The truck has a few pretty bad leaks that need to be addressed as well. It has the CDL switch and apparently the PIN 7 already as well. Im not getting any CEL, but being OBD I I know they don't always show the issue. I plan on cleaning the throttle body, IAC and doing plugs/cap/rotor etc this weekend. What else should I look for as far as the idle issue is concerned? thanks in advance!
