Just got a 1980 40 delivered from across country. It looks like a great truck, no rust except some surface on the front door bottoms, so I was stoked to see it.
Here's the thing, it was driven to the terminal in California, so I know it ran. I get it here, after replacing the battery she fires up, but has two problems.
The exhaust is spitting oil when cold. I'd hoped that it was just some wayward oil from the trip, carriers often tip a vehicle almost vertical when unloading/loading other cars. So I let it run for about 10 minutes, the exhaust cleared up and the oil spits went away, problem solved - NOT. I started it up again today and the same problem, Oil spits and thick smoke - DAMN. I'm no mechanic, so please help me out. Since the "spitting" goes away after it warms up, is that the oil seals expanding after warm? So do I need to get the head rebuilt, new seals, ??? Any idea on costs?
The other problem, the tranny. I should mention that the truck is completely stock. When the key is turned off, I can run the shifter through all the gears, but once the key is turned on I can only push the shifter to reverse, which only grinds, wont engage. Am I Crazy, what is this??? I've had 13 cruisers, 1 79 model that did not do this. Since it's related to the key position I'm assuming this is some electrical deal?
I appreciate any help you can provide.
Thanks
Todd
Thanks
Todd
