'91 V6 Auto 4wd
I'm looking for any help replacing my Neutral Safety Switch. I say this because, currently, the truck only starts in neutral. I didn't learn this until I had also replaced the battery and starter,
but that's alright in hindsight because they needed to be done.
I can't get the switch past the shift bolt that the shift lever is fixed to. This bolt needs to be replaced as well because it's twisted, rusted and it sheared off with its nut. FSM basically says after removing the top switch bolt "remove neutral safety switch." Thanks, vague as usual. Anyone know what I'm up against here?
but that's alright in hindsight because they needed to be done.I can't get the switch past the shift bolt that the shift lever is fixed to. This bolt needs to be replaced as well because it's twisted, rusted and it sheared off with its nut. FSM basically says after removing the top switch bolt "remove neutral safety switch." Thanks, vague as usual. Anyone know what I'm up against here?
