Need some wiring help
Medford, Oregon
Need some wiring help MORE HELP PLEASE!!!!!
:confused: I'm installing an isolator with dual batt. I don't know which wire from the alt to run to the isolator. I have a v8 with the chev alt. On the alt is a plug with two wires one is short and goes from the plug to the post were the other from the plug just comes from the harness. The last wire is the main wire (I guess) that goes to the post also. Which one do I cut,splicedisconnect or what ever to hook to the iso. This sounds confusing as hell to me, I hope one of you guys knows what I'm talking about. Thanks for the help,Greg
I am pretty sure you just want to run the main power wire from the alt to the isolator. But I have never used an issolator on a dual battery set up, I use a selnoid.
Not knowing the brand of alternator, asuuming Delco - I would say your "main" wire should be the one feeding you isolator, that is afterall the switch that controls which battery gets the recharge juice. The alternator need as signal and exciter power wire depending on which type alt it is.
I can't be of much help because i have only really dealt with Delco "one wire" alts.
I guess you did see the wiring schematic on here, about all I can offer is to search the whole Pirate board and wade through all the post there. I'm sure there is a lot more correlative info there re 350 and dual batt installs.
Good luck.
Haystax, it's a delco. Can I get rid of the white/blue wire from the alt then and rplace with a new wire that goes to the isolator?
It depends on whether you want your amp meter to work properly. If so, then run the white wire that connects to the + post of the battery to the power in/out of the isolator circuit. If not, then you can run the run the B+ lug of the alternator directly to the isolator bypassing the meter.
Uhh, I really don't know if you should do that. The only ones I have dealt with are one wire, hook it to the positive and your good to go. The two wire with plug and hot wire I really don't know where the wires go, I always just plug them back in. I would have to take a look at how some Delcos we have are installed and trace some wires before I could really be sure I was telling you the right thing to do.
Where does the output wire of the alt go right now? Which wire went to your battery to begin with?
I am no expert in this regard, please don't do anything drastic without making sure you talk to somone besides me. I'll look some stuff over in the morning and check back.
Good luck.
hey secretagent, i have always ran the wire that goes to the battery with the fuseble link in it to the isolater and from the isolater to the battery's and never had a problem hope this helps and isnt to late. didnt the isolater come with directions, i could maybe find the direction's to my old set up if i look around, but that's how i had it set up on my old chevy truck. i drove it for years that way. GOOD LUCK!!
What I have now is the white/blue wire attaches to the + lug on the alt and goes into the harness (not sure where it goes from there) but I think it's goes to the +side of the battery, there a smaller wire that attaches to the termional that has a fuse link. I'm wondering if I can disconnect the wht/blu wire from the alt and just run a new wire from that + lug to the isolator and get rid of the wire at the battery terminal. I'm not concerned about the amp meter, eventually I'm going to do different gagues in the dash. Thanks for all your help, I'm lacking severly whenit comes to wiring knowledge, so I look to you all :cool: Thanks again
secretagent have you looked at the wireing diagram, i think that wire goes to the amp. gauge and then to the battery, i dont think it goes threw the old voltage regulater. so you should be able to just run the wire straight to the isolater if you dont need the gauge, check the diagram and if thats all it does then you will be fine. good luck!
Does this help?
Hope this helps. I don't know a damn thing about it.
Looking at our various setups - just run the main wire from the terminal to the isolator and you're good to go. Sounds like that's what all the people who actually know what they are talking about came up with as well. I couldn't find anything that runs an ammeter in our junk either, but it sounds like you are on the right track.
HELP needed despratley
Thanks for all the help so far. I think I got the alt/iso wiring figured out. I have all the batt cables run but it doesn't seem to be right either, what a PITA this is turning out to be. I have a cable from the starter to the common post on the marine switch, cable from from marine switch to each battery and another from switch to the iso for each battery, seems pretty straight forward. On main batt (#1) gound to block and cable to the switch, batt #2 for auxillary stuff positive cable to switch and gound runs to neg side of batt #1.
Problem is when the marine switch is in the OFF position (Meaning no batteries juice) my headlights still come on and the starter 'clicks' but doesn't engage. When I turn the switch to run just the #1 battery I can start the engine. It seems that when in the OFF position NO juice should be going to any electrical system. What have I done wrong. Should I remove the ground from that connected to #1? HELP. few pics to show :confused:
secretagent i would run seperate grounds on the battery's, dont know if it will matter but on my old truck they were seperate. mainly because they were on opposite sides of engine compartment. and the wires from isolater to battery's should go to battery's not the switch at least thats how mine were. i also had the same marine switch and when it was off there was no power to anything, so i dont know were you are getting power from. oh and did the directions tell you to not turn the switch with key on or engine running, mine did thought i would mention that just in case, wouldnt want you to screw-up your alternater. good luck.
secretagent said:
Problem is when the marine switch is in the OFF position (Meaning no batteries juice) my headlights still come on and the starter 'clicks' but doesn't engage. When I turn the switch to run just the #1 battery I can start the engine. It seems that when in the OFF position NO juice should be going to any electrical system. What have I done wrong. :confused:
I wouldn't assume that anything is wrong. The way you describe the wiring, all the marine switch does is switch the starting current to the starter. Sounds perfectly reasonable that everything else would work then this switch is off. Obviously the isolator is still supplying power to the chassis with the switch off. What is the problem with this?
If you would prefer having everything shut off, you could just move the chassis power supply line (the big white wire with fusible link that went to the battery + post) connection to the starter power lug, which is now on the other side of the switch from the battery.
If you could post up a schematic diagram of how you have it hooked up, it would help.
PinHead, thanks for the advice, that's exactly what's going on and I was wondering if it was the fused wire on the batt post. I will move it to the starter lug so I can switch off and nothing works. I don't know how to post a schematic. I'll draw one out tomm and take a photo and post. Hopefully you can help. Again thanks. Oh ya look tomm for the schematic post.
