Need some stereo installation help
Knoxville
So my CD changer has crapped out after 10 faithful years. It looks like it's time for a replacement. I think I'm going to get a new head unit with built-in cd capability so I'll be abandoning the factory cd changer. The wiring diagram for the Lexus stereo setup looks pretty menacing. What I'm hoping for is a volunteer, who if I send a pdf of the wiring diagram, they could mark up what I need to do for the following option:
Replace the head unit and abandon the existing cd changer. I'm thinking that one's pretty straight forward, maybe just requires the right wiring harness to transition from the existing factory plug to the new unit. Then if I decide to install an after market amp, how I would need to wire it to abandon the existing amp and sub.
Let me know if I'm making this more difficult than it is?
Thanks,
Rookie2
you could go down to just about any car audio store and they'll have a wiring harness that will plug directly into your factory wiring harness. then it's usually just a matter of matching the colors to the new head unit. very simple install and it'll usually only cost about $12.00. just make sure that the head unit you buy is working properly, i made that mistake once. :o
also, if you've got the factory service manual the wiring diagrams are pretty straight forward if you know what you're looking at and what to look for. good luck.
What if you're going from the factory harness to the back of another new factory head unit? Can you buy a harness that plugs into the factory plug, then into the back of the new head unit?
IIRC, the wiring diagram for the LX is a bit more complicated than the LC. My understanding is the head unit and amp are tied together trough a common ground loop. So although integrating a new head unit appears to me to be relatively simple if I can get the proper harness, eighty-sixing the factory amp and wiring to put in a after-market amp, seems to be a hole different ball of wax. So I'm hoping for someone who's willing to look at the LX diagram and give a recommendation on how to go about this.
Thanks,
Rookie2
Bump... maybe I was a little overly ambitious in my request.
Let's try this another way. Has anybody installed an after market amp in an LX-450?
Thanks,
Rookie2
Dunno how similar the LX is to the TLC but their are 2 or 3 different harness adapters that will fix you up. One plugs into the OEM wide plug that's is used with the OEM stereo, then you have two gray plugs back their as well. The gray plugs are probly easier to use as it has more appropriate wires BUT the other harness has RCA's for plugging into the headunit. (It's labeled as a amp integration harness by Metra, the one that uses the two gray plugs is Metra 70-1761
