Need some Help! (oil pressure issue)
Chicago and CA
Hey Guys,
I have this weird issue with my 96. When I first start it up, oil pressure is normal, but as it warms up (5-10 min) it drops. I mean, it really drops.. when I am stopped at a light its completely on the L. Then when I drive off its barely off the 1/4 mark.
Here's my work-up so far:
1. No visible leaks under the car
2. Slight gasket leak (not sure how malignant that is)
3. Dip stick.. (here is where I am lost. It seems like the oil mark is normal, but there are two gradations of oil
a. a very light mark of oil that reaches the full level
b. a darker oil mark thats on the low level
...which should I read on the dip stick, does it sound like I should pour a quart of oil in and see how that changes things? or does pouring in that extra quart present other issues that are bad too?
I apologize for the remedial question, but its been bugging me and I don't want to be driving around with low-oil and ruin my rig.
Thanks!
1. Has it always been like this or is this something that started out of the blue?
2. Quantity of oil in the pan will not effect your pressure readings. As long as there is enough for the pump to pick up without sucking air, the readings won't change.
Thanks for the reply!
To tell you the truth I just began noticing that the gauge doesn't climb as much as it used to.
Just today, at moderate acceleration the reading was between 1/2 and 1/4. It doesn't seem to climb to 3/4 or higher when accelerating. I could maybe just be something I noticed.
Fluid levels are fine, I just checked.
I guess my question then is, where are your oil pressure readings at when accelerating?
It could be that I just never paid much attention to it before.
Mine will go to 3/4 or just above when accelerating (I watch it all the time). It will just be a tad under 1/4 at idle but usually right at a quarter. I wonder if it is your sending unit at fault?
when I moved to a heavier oil, rotella 10/30 my oil pressure across the board went up over having lighter oil. I doubt anything is wrong. the two oil marks on the stick is weird, do you pull it, wipe it off and then put in for a reading? Or just pull it out and read it after the truck has been running?
There is an low oil light. Make sure that works by checking it just before you turn on your ignition switch to engage the starter. The low oil light is usually pretty touchy and will turn on when a little low as others have noted on other threads(about a quart low but still above the lowest line on dipstick). As long as your oil sending unit is working I think you are OK for having just enough oil in the engine.
I noticed that when it is hot the oil pressure always seems lower. I switched to 15W-40 Rotella T and now its always at 3/4 when accelerating, and when I idle its half way, or a tiny bit under if its 100+ outside. Mine is a 3FE though so it may be different with than yours.
Not that it is a direct correlation, but my '06 Tundra's oil guage reads 1/2 w/ heavy acceleration and 1/4 running down the highway. I think I'd be more concerned with changes in where it reads (i.e. starts reading at 1/8 when it used to at 1/4) than where it is now. Just an opinion though.
My gauge tends to run around halfway or a bit higher when the oil has just been changed. Over the lifespan of the oil it will gradually drop. I'm not sure if I spill oil on the sender unit when changing the filter and that is what causes the slight change in readings, or maybe the filter is getting clogged over time.
FWIW, the stock oil pressure gauge is only there to say "yes, there's oil in here somewhere", rather than to give an accurate reading. Many have changed to a "real" oil pressure gauge, but as long as mine moves and shows signs of life, I'm OK.
As another data point ... mine is typically right at the 1/4 mark at idle and almost always at the 3/4 mark upon any acceleration, it'll settle at 2/4 if I'm highway cruising with no load. I do not notice a "drop" with new oil after awhile. I use M1 5W40 when I can get it and 0W40 when I can't get the 5W40. BTW, When I run the 0W40 I notice that the cold oil pressure is a little lower and I also notice that I "use" a little more oil over the interval - I think part of this is that my pan arch only seems to seep with the 0W40. With the 5W40 my cold oil pressure is a little higher and I have virtually no leakage at all.
As others are suggesting, the stock oil gauge gives you an approximation of what is happening in real time. Therefore if you have had any observable drop in oil pressure I would definitely definitely look into it! It could be something with the oil pump (pretty rare AFAIK), an obstruction somewhere (little more common), or an opening somewhere allowing leakage. In any event the only peace of mind you can get comes from accurately measuring the oil pressure during a variety of operating conditions. Some here have documented their findings from researching similar symptoms. Again, in my opinion, any observable drop should be searched out. HTH. :cheers:
Here's what the FSM says:
4.3 psi or more at idle;
35 to 71 psi at 3000 rpm. <-- fixed error (said 300 rpm first time)
Perhaps a proper presure gauge will answer the question.
Thanks for all the replies..
I checked out the dip stick after driving and letting the oil collect in the pan, and it was full.
As for the oil, I got it changed at a Toyota dealer and have no idea what grade they used.
I am in Chicago, should I switch to more of a 5W30 oil for the winter? Or will that just make the oil pressure issue worse?
This could be resolved by switching the oil.. that will be something I will try out.
Sam
