Need some advice on a engine purchase
Seattle, WA
Website
www.bladerunner80.com
Ok, so this guy I work with has an 89 Chevy Silverado, he put a new crate motor in it a while back (fuel injected Chevy 350), he says there is around 20,000 on the new motor. Anyhow, I guess someone stole it, then he got it back and now it has a bit of an overheating issue.
To the dilemma: he wants to get rid of it, and was going to donate to a charity or something, we were talking this morning and I was saying how I want to drop a new or newer motor in my FJ40 when I do my tranny swap. He offered to give me the whole truck for nothing, and he'll have AAA drop it off at my house. Currently its residing at an auto body shop. He said the engine probably needs new seals, I'm guessing new head gaskets. It starts and runs, how well I don't know. He told when he put the new motor in, he spent around $4,000 for it. The drive train is in good condition as well.
The only thing I want out it is the motor, and I could probably part the rest of it out and get some cash. So what do you guys all think? Should I go for it?
He's a pretty good guy, I don't think he's trying to dump this thing on me as he could easily just drop this thing off a recking yard and be done with it.
Also, it it possible to take a 350 that has been setup to run on fuel injection and convert it to a carb setup? I imagine the only thing different is the intake manifold right? I thinking I don't want to deal with the hassle of putting a bunch of new wiring in for the ecu, or should I leave as is? I imagine I would get better gas mileage.
Thanks!
why would you want to go from fuel injection to a carb? EFI is wmuch better for an off road rig and better fuel economy as well. in any case i would take it no questions asked...take what you want and part,sell or wreck the rest of it...
I was talking with the guy and we're going to go and check it out. Yeah, the idea of fuel injection sounds cool.
Since this thing has an overheating problem, what should I look for when checking it out the engine? Is there an easy way to see if there is coolant in the oil with out pulling the valve covers off or draining the oil? Obviously when its running I can check for smoke in the exhaust.
well hell, even if the heads are warped, I'll have the thing out the truck. I could easily take them off, find a decent set on craigslist and slap those on there with some new gaskets. Not bad seeing how I got the the engine for free.
I think you guys are right......I would be stupid to pass this up, although I think its going to piss my g/f and my neighbors off having this thing sit in my driveway. God I hope the HOA doesn't ride my ass about it!
I second everyones opinion here. you could use the existing wiring out of the truck and just swap it over. ECU and everything. as for switching over to a carb im not positive. The manifolds are different of course but whether they would be a straight change over I'm not sure. Is it a multi injection system or a tbi?
I generally take the radiator cap off and look for an oily residue floating on top of the radiator fluid. If there is none, I run the engine and look for bubbles through the radiator cap opening. If you pull the dipstick and the oil looks milky you have a problem. These little tricks will not tell you if you have a slightly blown head gasket.
If the smoke coming from the exhaust is white you have blown head gasket. Make sure you let it warm up. It may not blow white smoke until it's warmed up. If is is dark gray or black and then quickly goes away you generally have bad valve guide seals.
I agree with D'Animal I did the same stuff, I only had to do it once though but it still worked. And Bladerunner80 I would be more than happy to take just the fuel injection part off your hands.
Thanks for all the tips, I'll keep you posted on when I go out to check the truck out. The idea of running fuel injection is started to sound pretty cool, but we'll see.
So what are you going to sell the 89 Chevy for?
If you do decide to go with the carb setup, i'll take that fuel injection system off you. Although if I were you, i'd definately stay with the fuel injection.
Good luck either way
Kevin
I definately going to go the EFI setup route, it makes much more sense the more I think about it. I talked with the guy and I'm going to hall the truck down to my place next weekend, then its time to part it out!
Why you need a banged up chevy body? Hell, I just want enough so I can buy my coversion parts for the SM465 I bought!
Is it 89 silverado? Is it step side? How much would it be?
No, it not a stepside, just a 2WD pickup. Where are you located? Its getting dropped off at my place next weekend. I'm pulling the motor and possibly the transmission. I'm hoping to get around 500-600ish out of it, so I can buy the parts i need for my tranny swap. I'm going to look around and see what a pickup is worth w/o the engine/tranny. The body is in perfect condition though.
I would recommend getting the engine running properly while it's still in the truck, then take it out.
I agree with F-junker to get it running before you take the motors out and trans out. I am in Ramona, California 92065. Can I have picture's of the truck?
