Need replacement stereo, maybe GPS? which one?
Hudsonville, MI
Newbie here. Wifes 2001 has a bad cd player and won't load, it just makes a grinding noise for a few seconds when you start it up. Bought a replacement unit from a 2000 model, only plays music, no audio controls work or cd player. Must have a different control unit than the one in wifes truck.
any suggestions on what to replace it with and who really knows what they are doing. Wouldn't mind a GPS unit if it is reliable. The mass mart stereo shops around here seem to just cut up your factory harness and just make it work, not impressed. Would like to keep the factory speakers and wire harness.
Thoughts? :popcorn:
get one of those double din radio units by kenwood or pioneer. The alpine looks nice too.
I have a Kenwood DDX-7015, few years old but it still works well. I would love to upgrade to one of the newer models.
I installed a JVC AVX800, bought from CC for around $600. It was a little cheaper than some of the other units that were available. So far I have been very happy with it. Expandable for Ipod, Bluetooth, Nav, external screens, satellite, USB input, whatever. I use it with the bluetooth, had the Ipod kit but returned it because the integrated SD card slot was soooo much better. I wish it had HD radio but for the money, I can't complain.
Avic-Z2. straightforward DIY install with aftermarket adapter harness. a does-everything solution that works with OEM speakers & sub
Pioneer AVIC-Z family
I second that opinion on the Pioneer AVIC-Z2.
I installed the AVIC-Z1 (Pioneer upgraded software and now ships it as Z2) product.
Used Crutchfield's included wiring harness. No hacking up of any factory wires was required, but some splicing (attaching new wires to different points in the vehicle's existing wiring harness) was.
It's a double-DIN unit that includes HDD to store all the GPS maps and up to 20GBytes of your music (rips the CDs as you play them).
Also bought the bluetooth and iPod adapters.
Has lots of extra connectors dangling in the back to attach extra video monitors and auxilary A/V inputs (like a backup video camera or Sony Playstation).
Plays Video DVDs.
Nav works quite well.
Sound is better than the stock system. Used the existing Toyota factory amp found under the front passenger seat, and was already wired to the wiring harness.
There are a couple of wires you have to connect to give you full functionality, like the Speed signal and Backup signal, as well as Parking Brake. You also need to connect the "power antenna" signal.
It took me several hours, but was well worth the effort.
For the money, you can probably find a bunch of other vendors who have better deals. There's plenty of competition as you can read from the other posts in this thread.
You can search one of my old posts for "cd player crapped out" or "AVIC-Z1".
the -z2 user interface is pretty slick (touch-screen & panel buttons) and you can also get an inexpensive steering-wheel mounted wireless controller to manage the most-frequently-needed functions ala "hands on stick and throttle" (this is without a doubt my favorite and least-expensive add-on). z2 has voice-activated control functions as well, but the steering-wheel thing is way easier. I have my b/u cam plugged into one of the video inputs and my Ham rig (which spits out color-screen and mono-audio signals) plugged into the AUX-in ports. I-Pod adapter interface is transparent, although the search function could be better. sirius and xm radio adapters all work as advertised, bluetooth phone works great (some users in smaller cars report excessive audio feedback, but i think this is based on the interior size & where the mic is mounted... i haven't had any problems in the -100)
My kids are gone-to-college now so i didnt add the rear-seat monitor option, but if you go that route the folks in back can watch dvd on their screens (with headphones, presumably) while the driver/fp listen to something else. This thing is amazing - well engineered and reliable. if you pull the trigger on this make sure you get a newer (e.g. post FEB 2007) mfg unit as the older ones had a defect in the firmware which caused heat-related failures for users who live in warm-weather areas. check out avic411.com for more info, etc.
not that *I* would do this, but there are easy hacks that let you bypass the nav inhibits (like the one that forces you to stop in order to use the distination routing function). The nav is quite sophisticated and offers 6 (if i remember right) different real-time visual mapping display modes, one of which is a split-screen that engages the b/u cam. some guys are replacing the internal hdd with a larger capacity variant to expand their music capacity. this path is technically demanding and you need pc hacking skills to properly transfer the pre-loaded nav database, etc. I think the better solution for that is an I-Pod which could also deliver stored DVD and video-Podcast contnet thru the -z2's aux-in port.
as zj2uzj100 indicates, the installation is not a challenge: using the oem harness adapter, the bare unit & antenna & mic wire routing can be done easliy under 2 hours, although mounting & routing teh small boxes & wires for the optional adapters (I-Pod, Bluetooth, sirius, xm) will require that you remove other panels (I put all these things under the center console & behind the map-box), figure an afternoon to do this. Install this yourself! There's also the option of going aftermarket speakers/amps/subs (I didn't) and the -z2 offers lots of configurations for amp/sub in-out and comprehensive "sound-stage" and level adjustments via the touchscreen
well worth the relatively high price if you want to a complete A/V experience
x4 (or whatever) on the AVIC family. Had a Z1 installed about a year ago--my first nav device. Very, very nice. Have done at least 5K miles of road trips using the nav and it is spot on about 98% of the time. Love the music storage function. Looks at home in the dash.
I would (and did) install an eclipse model. There's a reason it's the OEM equipment, it is the best GPS Nav installed system. Finding an address or POI is easy and the system is user friendly.
I bought the AVN-5495 for the hard drive installed Nav with the ability to play DVD's for the kids on longer trips. With this system, and headrest monitors, I can use the Nav system while they watch their favorite movies. For my purpose this was the perfect setup.
