Need realtime electrical help.
The :princess: went to take big blue out for a drive. Apparently she got in, started moving the seat up, inserted the key and heard a poping sound. Now there is absolutely no power at all. Nothing will work, horn, windows, doors etc all dead.
I checked the batter and it has 12 volts I checked all the fuses I could find under the hood and under the steering wheel and they all seem good. I checked the fusable links in both the fuse box under the hood and under the steering wheel, they all test fine.
Only thing I can get to do anything is the keyless entry will triger the relay inside the TSS box.
Anyone have any ideas? Location and a good description of what to look for are appreciated as I'm really new to the 80.
Is there one right off the battery? I see a black box with 2 wires in and out. How do I test it?
That's it.
How do you test it? Actually, I don't know; I've never had to. From looking at it, I'd say pop the box open and see if the wires are fried.
If that IS it, you really need to find out what's up. Those links are sort of the last ditch safety in case of a major ground fault, as far as I know. (Hopefully someone who's less of an electrical idiot will chime in soon. :D)
Curtis
I opened the box and all that is in there are two bolts connecting two wires in and 2 out. I don't see how this could blow?
My meter says I have continuity between the possitive post and the body although that does seem wierd to me. I don't see how without blowing a fuse that I can't find?
There are three fusible links coming off the '+' post. Two links, like Curtis said, go to the little black box, and, IIRC, the other has a grey connector on the end.
<<see pic below>>
Found it:
Red: 2 links to the little black box
Blue: link with grey connector
The thing with this though, is there are more connections to the body than just through the links.
you *shouldn't* have connectivity from the + post to the body, right?
I'd start by looking at your starter cable (ie: the cable from battery to starter) those get corrosion damage and/or worn insulation pretty easily. That could be it.
You can further test the fusible links by checking for connectivity from the battery to the fuse box (in the engine) if you don't have a connection, that could be the fusible link (or it could just be an Aux or On connection, apply some critical thinking there as I don't recall which are which)
I think you can also check the fuse links by actually feeling the links-- a blown link is actually fried within the insulation and you should be able to feel that, I think.
If you haven't already-- also check the connectivity on both sides of each fuse, should only take a second and is more reliable than looking at the fuse.
K I checked under the hood again and I don't see where the third one could be? The black box says "am1 main". What I don't understand is how that could blow without burning out the bolts somehow? how do I test it? I took the box out and all it is, is a box with two posts with washer type connectors that touch when the nut is on, this can be seen in your picture. There is one more wire that goes to a grey connector and then it disappears into the harnes? Why couldn't Toyota have used a typical main fuse?
K I checked under the hood again and I don't see where the third one could be? The black box says "am1 main". What I don't understand is how that could blow without burning out the bolts somehow? how do I test it? There is one more wire that goes to a grey connector and then it disappears into the harnes? Why couldn't Toyota have used a typical main fuse?
It's actually "AM1" and "MAIN". Close, though. :)
A link can blow without showing anything on the outside. If they haven't been replaced, you should replace them. Like $11 from the dealer. Worth the $.
Check fuses, relays, other links. Check the fuses one by one, pull them out to look. Do you have a FSM?
Great! Now I can get some sleep!
Wait, don't you need to figure out the popping sound too?
The popping was the battery posts arcing inside the clamp. It use to happen to me all the time in my old yellow truck....
Pop hood, jump out, wiggle battery cable, close hood, jump back in, and off we'd go. Sorry I didn't see this sooner, but I am glad you got it figured out.
