1996 LC, 180K miles on the clock. Left me stranded at grocery store parking lot. Here are the symptoms:
1) Turn key, starter doesn't even crank. All the dash indicator lights do come on. I noticed that the gear indicator was not quite on P, so I shoved it into P, no luck. Putting the gear into N doesn't work either. Won't start in any of the other gear positions.
2) Battery voltage is 11.7V measured with a voltmeter.
3) Vehicle has an aftermarket remote start system (Viper). It also does not work when I try to use it to start, although the alarm sets properly and unlocks/locks the doors. Key fob battery is fine.
4) I have checked the fuses for the IGN system and the ECU, they are fine. However, I don't know where the starter relay is located. That would be very helpful if anyone could tell me where it is. I don't have FSM.
5) Can anyone help with a pinout of the park/neutral switch from the FSM and how to check it?
