Need Part Identification (1 Viewer)
Puerto Rico
I'm doing some minor leak maintenance from my Engine rebuild.
I'm finding some leaks that will be covered in this thread.
My First Unknown Part # and it cant seem to be found by my Parts Dealer is the gasket that goes here...
I will assume this is a heater hose gasket by I can not find the part # anywhere, I used an air conditioning gasket that had a similar diameter steel ring, but as you can see its failing via the bolts and leaking coolant in this area.
Can someone give me a part# or an alternate way to solve this.
Thanks!
Puerto Rico
THANK YOU!
You have no idea how long we have been looking for that part #:D
I also have a leak from what looks to be the INSIDE of the distributor (oil)
and another from a seal IN the Power Steering Pump (not the O-ring that mates to the engine) something to do with the PS pump shaft.
are there any rebuild kits for any of those 2?
I would think there would be a Rebuild kit for the PW Pump or a list of parts to do the rebuild? Seal wise, the pump works well....
Puerto Rico
OK,
I found the PS Pump Seal Kit for about $30 at my Toyota parts dealer.
Later in the week I will open the Distributor to take a closer look at the leak.
I was told there was no rebuild kit for this type of leak (if its coming from the inside of shaft) and a new Distributor would be about $330:hmm:
So I will inspect it carefully to find out where the leak is coming from...
If it needs replacement I will contact CDan or Beno for a quote, maybe the can have it for cheaper even with shipping to PR:cheers:
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
