Need info from a 60 owner.
NE GA
I disconnected the fuel lines on an 87 60 I am working on and need to know how they go back.
there are 2 hard lines from the tank, where they come off the frame in the engine compartment, there is a forward one and an aft one,
there are 2 lines coming out of the top of the mechanical fuel pump, one is closer to the engine than the other
which hard line from the frame goes to which line on the fuel pump?
I believe one of the hard lines from the frame goes to the charcoal canister, is this right?
then which hard line in the rear goes to where on the tank?
I am not at the truck right now and do not remember if there is a third line off the fuel pump as in the diagram I am looking at now...
the hard mounted lines on the frame.
The one to the front (closest to the grill)is the fuel feed line (inline fuel filter on this line)
second is the fuel return
thrid (closest to the firewall) is the breather line for the emissions. It did go to the charcoal canister
as for the fuel pump hook up, i can't remember, but the only lines that hook to the fuel pump other than fuel feed line to carb are the feed and return line. hook the feed line up, have a buddy turn her over and if you see gas skeet out the other you know you got her right.
