need help within 2 hours
out a set of longs in it with pig's inners.
Good to 38's
TwEaK said:
What is the max size tire you can put on a 78 f40 with stock drivetrain ? Rim size combo ?
guys in aus fit 34's under there no lift some trimming of the fenders.
start tubbing the body you can fit a 38 no lift.
35's might start to stress the cv's (i've broken one on 33's)
the rest of the drivetrain is pretty strong
if i may ask how have you managed to break one? what were you doing that it broke??? cause i was thinking maybe a 4" lift with 33" should be fine with a nice winch in the front i should be good to go and enjoy it a little dont ya think?
TwEaK
i was driving down into a creek, my front made it over a big ass rock, my rear got hung up on it, so i tried to reverse out very violently (welll progressively built up violence), which ended up with me dumping the clutch in low reverse st with a heap of lock on the steering wheel... with most the weight over the front wheels (nose was on a steep down hill)
considering the cv's were 29 years old it's not too bad, i also grenaded a front hub at the same time. should have just got pulled out backwards
Looks like a nice Cruiser TwEak. Might want to check out the springs, looks like they are sagging on the driver's side. Congratulations.
Go with the 78..........rust repair is a huge expense. For example, I was looking at $1600 to replace the rear sill, inner fenders, and floorpans. That was only the inside of the tub.........what about in 10-15 more years? Fix a bunch of rust on the outside, too? I went fiberglass instead. Good luck!
thanks guys appreciate all the help well this one has minimal rust he says there a small spot of rust on the floor pan that has just started and also a hair on the firewall the firewall got me thinking for a little but im taking the guys word hoping that it is just a small rust spot.. the springs sagging are you talking about the rear quarter ??? i will admit looks like the truck is sagging in that one spot ill check it out when it gets here... ill let you guys know more info soon and last question if im in Miami,Fl how do i know of other cruisers that are in the area to mayb go trailing with sometime??
Thanks
TwEaK
TwEaK said:
cant find that lol can you give me a link?
Thanks
TwEaK
When I move to FL in a year or two we'll go out togheter
unfortunately the only club in FL is the one in Lakeland in the Orlando area
a bit far for you
http://www.ih8mud.com/toyotaclubs.php
maybe you can start one
I am going to move in that area Deltona/Lakeland /Orlando/Daytona
don't know yet
go to the ih8mud forum and scroll about 2/3 of the way down and you should see clubhouse corner. that's the one i'm talking about. i've just recently found this myself. i'm on my wifes mac and can't get the link up, so if you still can't find it i'll post a link in the morning.
Hey I am on a Mac as well the link is working
https://forum.ih8mud.com/forumdisplay.php?f=31
but again this is the only FL club .. Lakeland area a long way to Miami
real quick question what company makes the intake to run the intake outside i forgot the name of it right now but the plastic piece so you can run the intake above to where the roof is?
TwEaK
