need help with my door locks 04 LC
Sorry, one more question on this. At the moment there seems to be no automatic locking or unlocking at all. If say I were to enable Mode 1 and Mode 4... how could I then switch it back to having nothing automatic?
Well, I just tried to do it without success. Entered car, all doors closed, switched key to ON (not starting engine) with gear stick in Park, pressed driver door lock switch for 5 seconds then released, but nothing happened. Also tried it in Neutral, same thing. Also tried the same with the door switch rear position. Did it a bunch of times, even used a stopwatch. With none of them did I get a lock/unlock confirmation. Not sure what I'm doing wrong. Unless this car doesnt have that function - its a Japanese import but from what I've read automatic door locking is mandatory there so that seems unlikely to be the issue. It does appear that someone fitted an aftermarket alarm system (not functional now, no remote), could that be the issue?
Hmmm... can't speak to whether or not the JDM model has that feature, but the alarm should tie into the locking system. If it was the VIP system I would say you would stand a better chance of an auto-lock feature remaining intact, but some of the aftermarket installers just snip wires they don't understand and put there stuff in. :meh:
Reading this thread and successfully getting the locks to unlock on my wife's 05 LC has just given me a few days of 'free time' to browse MUD without the "are you addicted to that site" question. Mud does it again!!!
Randy
This is how I got this to work. I began by placing the shifter in neutral FIRST, then proceeded to follow the instructions exactly as described by Topoguide in his post above. Placing the transmission in neutral as a first step allowed me to then “shift the selector lever INTO the ‘P’ position” as specified.
Confirm this worked on my ‘03 LX. Thanks for all who have provided the detail on the different modes and instructions. Mine was in mode 1 since I bought it, and just thought there was something wrong when it wouldn’t Auto Unlock the doors after putting it back in P like my old RX’s would. Just when through the process and changed it over to mode 4.
Bump
Is there any solution for my 99 lx470 that locks me in every time I turn the car off and sets off the alarm every time I get into it?
Is this a fault or a matter f programming?
Have no idea what to do
There is a set of steps in the manual that will let you change this. When I put mine in park, the doors unlock.
I finally pulled this off. Thank you. I also had to start the process in neutral and then shift to park as well as to be exact on the 5 seconds.
