Need help with light setup
Reno, NV
So after spending hours this weekend reading all of the LED/wiring/driving light threads, I think I finally settled on a lighting system for my 80.
2 Lightforce 240 XGT 50W HIDs up front for high speed/distant illumination
1 LifetimeLED 50" LED light bar on top of rack for low speed flood
3 LifetimeLED 10" LED light bars (DS, PS, and rear of rack) for light when setting up camp, etc
Now the question is how to wire them... For the lightforce lights, I plan on getting the slee headlight upgrade and auxillary harnesses. The lightforces will be linked to the high beams but I'll put a switch inside so I can turn them off if needed. This part shouldn't be hard. Where I get confused (I'm not good with electrical stuff) is how to wire the LED light bars. I need to be able to turn them on individually depending on which light (or combo of lights) I want. I also want to be able to run them with the ignition off. Can I run a 10-5 wire to the roof (4 power, 1 ground) and then run that to a single 30A relay, with each wire connected to a switch? Or do I need 4 relays? Plan on placing the switches in the 4 slots in the center console.
You need as large a ground wire as power
I think that would definitely simplify things!
Can I still run a 10-5 wire and have everything share a common ground? Or do I need a 10-8 so every light has its own power and ground?
I was going to suggest a blue sea Aux fuse box wired direct to the battery. I would at least run a separate hot and ground wire to my 50" bar.
So if I cant run a common ground for all 4, maybe a 10-6 wire with a common ground for the 3 smaller lights and a separate ground for the 50"?
They'll need to be on separate relays.
I wouldn't hesitate to run the 10/6 wire.
I'd wire your relays for the 3 small bars to power both 12v + terminals and then control them in cab through ground. Easier than tapping into a 12v constant hot in the cab for the relay/switch if you ask me.
For the bar you could just wire the relay to be powered by the high beams and batt + and then run the ground for the relay through a switch in the cab. Switch off and you won't have the bar, switch on and you won't have the bar until you energize the relay through the hi beams.
Wiring up a 12v key on to the switches and they will light up when your lights are on.
Figure each small LED pulls 4 amps. The large LED about 25.
For your lightforces but run 85 through a switch.
For the others. Wire them so you have 86 and 30 to batt + and 85 to a switch in the cab that connects to ground.
That's just how I would do it though.
You can always run a short lead of appropriately gauged wire from your positive post with a ring terminal at one end and fused. Then you can bolt each accessory to that using a ring terminal for every accessory and a short bolt and lock nut. Just wrap it up tight with electrical tape. It's not as umm 'proper' as a junction box but it'll work if the lights have you tapped out. Helps keep the clutter on the battery terminals down to some degree.
Quick question.....I am running a large light bar on my rack and the ground work but produces a high pitched whine. I used my power probe to give it a perfect ground and whine went away. So is there somewhere relatively easy to get to through taking the map light off to ground ut or do I need to route it down the A pillar and some where else?
