Need Help with brake rotor
wetside of washington
I have a new rotor for the front driver side brake. What else do I need to complete the change. I have to take the bolts off to remove the rotor, do I need any other parts. If so what are they so I can get them to fix my brake. Thanks Jason
I am not an expert but i thought most people recommend doing both at once. I guess if that is financially impossible, then you deal with just one.
I would recommend looking at the FAQ's at the front birf rebuild section along with the 2 (or 3? ) rightups on rebuilding calipers that are in the faq as well.
What problems are you trying to remedy? warped rotors? worn-out brake pads, stuck caliper, leaky hub seal? other?
You gotta tell us what you are trying to fix B4 anyone can answer your questions.
I trying to fix a warped rotor. It wobbles when brake is applied. I already have the new rotor and I took the tire off and wham there is alot of bolts that are holding on the rotor. I just want to make sure I have all the parts to fix the wobbling problem. Thanks
Call cruiserdan (AKA CDan) at American Toyota 800-432-6668 for all your parts needs.
He will be able to set you up with everything you need to get the job done.
Be sure to tell him you found him on IH8MUD for discount pricing.
I have called CruiserDan before and great prices and fast and cheap shipping...
Jason,
I am 100% certain that Dan will not recommend replacing *one* rotor. Your post certainly sounds like your goal is to replace only the DS rotor. If we are reading you correctly, that is a bad idea.
Before you call Dan:
To understand what is involved with replacing the rotors you should first read the FAQ section that describes the process. At a minimum, it will be documented in the "front axle service" section of the FAQ. We might have other threads that are specific to brake jobs but I am certain it is in the axle service. Hopefully, you have a FSM on hand so you can get the torque specs correct and you will have what you need to lead you through setting the wheel bearing pre-load.
There will be a list of parts in the front axle service so double check there but you'll need a couple of gaskets and a grease seal for the back of the hub and a snap ring for the end of the stub axle. You might think about new wheel bearings. You'll also need a tub of HD wheel bearing grease. You should have new pads on hand; most recommend the 100-Series front pads since you will have new rotors.
-B-
How did you isolate the problem to a warped rotor? How did you isolate the problem to the left side? Are you sure you know what you are doing here.... cause your brakes are pretty important and this is NOT the place to start learning solo how to wrench on your truck.
(No offence dude.)
-B-
And a 54mm socket, fish scale, possibly a brass drift or two, and a couple other tools to make the job easier. Replacing the front rotors on this truck is a more indepth process than it is on most North American cars. It is not a simple "bolts off, bolts on" job. Not trying to scare you away from working on your truck (I owe all my mechanical abilities to my truck and this forum) but you should make sure you know what you're getting into here!
:cheers:
Jason,
-B-
The rotors on the truck or fairly new, as with the brakes. But there is something wrong with the drivers side rotor on the inside of it. I pulled off the caliper and looked at it the other day and there is something wrong. I already got new brakes for the front and will change both sides out when I replace it. I could take it off and have it turned but I thought a new rotor would be better. Then get the other rotor turned for a spare in the future. Jason
I replaced one rotor on my '97, no drama ensued. The wheel bearings need to come out with the rotors, you should replace or re-pack them while in there. And once you're that far, re-packing the birfield joints and replacing trunnion bearings and axle seals is just a little more time. It'd be wise to do the complete job instead of 10% when you're doing 80% of the effort pulling it apart. Look at this giant FAQ post from the top of this forum, and mine below, there are more but this is plenty.
https://forum.ih8mud.com/80-series-tech/78276-front-axle-rebuild-faq.html
https://forum.ih8mud.com/80-series-tech/17819-wheres-birf-faq.html
Are you sure that there isn't a problem with the caliper or the bearings?
If the rotors are fairly new then it is possible that the bearings on the trouble side were not preloaded properly. You can test this by lifting that wheel off the ground on pulling on the top of the tire. Should be no play at all. You have to do the test with the tire on or else you may not have a enough leverage to see any existing play.
Commo,
Some good advice here. If you have an issue with only one face of your recently replaced rotor then you need to understand what that's about and you're not really giving any details to folks here who might make the call in literally seconds.
Having said that, many people will replace a rotor or have it ground when it is not needed and I suspect that's what you're about to do because you haven't mentioned any symptoms or problems with the brakes just that "something wrong with" one face and you have pulsing. Brakes are not rocket science. Recently, our pastor's wife ground a front rotor up by using the pad material down to the backing plate. He and I merely replaced the pads on both front brakes even though there were grooves in the inner face of the rotor where the pad was shot. I bedded the brakes and the truck stops like new. Yep, the pads are undoubtedly grooved now to match the rotor but I'd be willing to bet 40,000 miles from now the rotor will be flat again when it needs pads again. Just an example that you may be overthinking this. Consider taking emery paper to the inner face aggressively, then just driving it.
DougM
I just finished a front brake caliper rebuild thinking it was what was causing some "pulsing" along with abs light. well the abs light is gone but the pulsing is still there...make sure you got it right! I know now it is my left REAR rotor so i got two new rears coming...whoops!
