Need help with a restoration strategy
Santa Rosa Valley, CA
Hey people. I picked up a 78’ 40 a little less than a year ago. It’s in semi-decent shape now, but I’d like to get it to the point where it looks stocky and new. Well… stock with a 2” OME lift kit and some 33s. I gave myself a couple of years to do the work (I have a lot of things going on and 2 years may be optimistic) and I’m already behind schedule. I live in CA and this thing doesn’t have a cat so I can’t drive it until 2007 anyway since it probably will not pass smog. In ‘07 I get a “get out of smog free” card.
So, basically I need some advice as to what really should be done to this thing so I can plan out this project. As some background on myself… I’m mechanically inclined, but don’t have any automotive experience. Given enough time I’ll be able to figure out a 40 though while working on it nights and weekends.
There are some things that intimidate me about this project right from the start other than having a truck in a thousand pieces occupying space in my garage until the end of time.
1. Stripping the paint and rust off this thing. To sand-blast or not to sand-blast? I doubt sand-blasting in my garage would be worth the effort, but hauling the frame, tub, plus miscellaneous other parts to who-knows-where to get blasted presents some logistical problems.
2. Welding new metal to repair some rust and holes. This seems like something I could take on myself.
3. Painting the damn thing when all is said and done.
Of the restoration process which steps are not worth the time and effort and should be outsourced?
I’ll follow up this post with some pictures.
this is a tough question to answer as "not worth the time and effort" is based upon one's opinion. Personally if I were rebuilding another 40 for the road and light trail use I would take the whole thing apart, repair the rust and weld in any panels needed, send the body panels and tub to a body shop to do the final minor bondo work and paint, I would also send out the frame to be sandblasted and powdercoated. Then really most of the dirty work is done and you just need to put it all back together. If rebuilding the engine I would send the block and head out as well. This is just me, others would rather do it themselves. I spent 2 years rebuilding my 40 on a slab of concrete outdoors and did it all myself (well, with a good friends help as well). All the scraping, chemicals and s*** was a pain. In the end though, I wanted my truck to be a trail rig more than a street rig and did not want to worry about dinging the paint, etc so I rattle canned the whole thing, came out ok, plus if I dent it, I can pound it out and repaint easily. Mostly I was working on stopping the rust process rather than making it look perfect. In the future I want to do a 55 and plan on pulling the whole thing apart but outsourcing most of the dirty work as I mentioned above. The 55 will be a street, bone stock, grocery getter. Let me know if you have any other questions or if I can help at all.
Noah
Here are the problem rust spots
This is the worst of it. It's better underneath. Just some surface rust. Here and there. What do you think?
For the frame.. off, blasted, dipped, powder-coated, $$$$, $$$$? Or go the sanding, wire wheel, etc and POR15 it?
For the sill.. Should I cut this one out and replace, or patch/repair and let it go until it really gets bad?
The rear door looks like it probably has rust inside, but probably not worth cutting it open.
Little bit of fender rust and some holes..
The right fender has this rust wearing through the paint on the top and bottom. I can't tell how serious it is.
Both fenders have a rust spot wearing through just behind the turn signals. This looks like it would be easy to cut out and replace with new metal.
The holes drive me nuts. The PO mounted a gas can to the side and the bolts went through the tub and top. More new metal and a little bondo.
List pics
The PO must have hit something pretty hard because the right side of the tub is bent in a bit just behind the step. Looks like it can be bent back into shape, but how do you do that? Just hammer away or should I heat up the metal with a torch first?
And a shot of the engine compartment. The engine runs fine, but one the cyls is weak. The other 5 are great so I'm hoping it might be a something minor. I'd like to avoid the expensive a rebuild since it only has 130K on it.
So what do you think?
Is this thing a candidate for a frame-off total restore, or should I try and take shortcuts. The interior is great, but it needs to be painted inside and out.
you said decent shape.... looks like pretty damn good shape to me
That thing has very minor body work!!! It is almost perfect. I will post some pics from my tub I just removed, I will show you some rust!! Wire wheel it, and get some por-15, and some of the UV protected top coat, and do the front frame with that.
later
Ryan
restoration
I think that is one of the cleanest rigs I have seen. Take a look at the link and see what I went through to get rid of a little rust. http://photos.yahoo.com/ph//my_photos
If I had it to do over again, I would. I have minor mechanical skills and no body work skills at all. I took my time and put everything in marked plastic containers and bags, also photos. It can be overwhelming at times.
When I think back on the should ofs, could ofs, I wish I would have rebuilt the transmission/transfer. My motor is fine and I did rebuild the axles. As for the frame I used a grinder and por. It really needed to be blasted for the best results. I did have most of the body that I kept sand blasted. I live in a small town and we have one. Good luck, if you need more info just holler. Bill
That is a very clean rig! 78's never came with catalytic converters. I'm not familiar with California laws, but in Georgia, they know what vehicles came equipped with cats and which ones didn't. Non-cat vehicles don't have to pass as stringent standards. You might want to get it tested so you can get that 40 on the road!
You might want to check into the CA smog laws. Try the CA DMV website. The exemption for smog testing is for cars and trucks 1974 and older. The new laws require you to pass smog every two years. The 30 year law no longer applies.
No cat converter for '78, but you will need to have the factory smog equipment.
condition
The PO took really good care of it. He had all the service records and everything. I paid a premium for it. 40s DO NOT come cheap in this part of the US. I looked a long time and this is the best I could find at a somewhat reasonable price. It felt like he was selling me one of his kids. He even sent me an email after a few months just to check in :).
Mr. "my 92 year old neighbor just had this 40 sitting in his garage for the last 25 years and wanted $1500 bucks for it!" I hate you.
It's a good rig and I'd like to get it on the road, but I want to restore it first. After the restore it'll mostly sit in my dry California garage and be taken around town on the weekends. I have a hard time keeping my hands off it though. Don't tell my wife.
So back to the restore... Given it's current condition should I do the frame-off? I just realized that I live about 20 miles from Man-a-fre. That could work out well. They could probably help me out in finding some places that do sand-blasting.
Thanks man,
George
George
You might want to check your emission laws, if this was a California spec and not a federal spec it had a cat on it. I think in 1976 California started to require a cat, the federal spec in 1979.
John
It is fed spec
It's not originally from CA. I checked the CA DMV web site and I was led to think that I won't have a problem in '07. I think I will go over it again.
Houston, I may have a problem..
From the DMV:
"How old does a vehicle have to be to qualify for a smog exemption?
Vehicles with a year model 30 years old or older are exempt from the smog certification requirements.
Example: The calendar year is 2004- 29 = 1975 exempt year model
The current calendar year minus 29 equals the year model exempt from smog certification.
Vehicles exempt from smog certification are listed above.
Note: Starting April 1, 2005, the smog exemption for vehicles 30 model years old or older will end. After that date all 1975 and older vehicles will be exempt from smog certification requirements."
I suppose I'll cross that bridge when I come to it.
no need for a cat on a 78.........
I really don't think you're going to have a problem passing. Your engine is stock, and looks like it has all the emissions still on it. Don't worry about waiting to be considered "excempt"
On a side note, I passed in Georgia with no emissions equipment on the engine. Of course, I had to buy a gas cap from the station for $20 (it didn't even fit). Those guys are crooked.
