Need help! Wheel offset impact
Colorado
I picked up my LX from Dissent yesterday. I decided to try a +25mm offset on the wheels. I’m having impact rubbing on the freeway when going in dips. Hits hard on the front drivers side. No issues in H1 but once above 65mph it automatically drops to normal so becomes an issue.
My question: the impact area is right where the fender connector pins are. Can I heat mold this area? Any other suggestions?
I need to drive 1200 miles back home on Friday and I’m worried about the damage. The fender is already slightly damaged. I’ve never dealt with this so would love some insight.
Consider getting Perry parts bump stops.
Also have an AHC height offset adjustment done to increase your ride height by 1/4”.
I’m guessing you have 35s?
Dissent should be able to do the height offset for you.
I got the Perry parts bump stops, also have a +40 offset and am running 35s without issue except minor rubbing at full lock on the front sway bar
Thanks. Running 285/70r18 Wildpeaks.
Are bump stops a good permanent solution to eliminate the clearance issue?
No and neither will height offset. The wheel still needs fit there when you stuff it.
I would ask Ben what his recommendation is but looks like something you can massage to fit.
I would consider the extended bump stops as a permanent fix. You need to limit up travel by a bit.
Here’s the suggested temporary solution I was given: add washers to existing bump stops to get 1/4” addition spacing. I’m also going to drive under 65mph for drive home (boring!) so H1 stays engaged.
I’m going to buy a heat gun today to try to mold the liner, but I’m uncertain how effective that will be given the location and liner shape there.
Once home I’ll order the Perry bump stops. Ben at Dissent has been helpful and even offered the take the +25 wheels back to exchange for +40, but I’ll try the bump stops first before going that route.
I should also add a pic of rig!
When you mold it do it in several steps and dont let the plastic get ‘shiny’ hot. I use a little cheapie rubber round head mallet off of Amazon or the dollar store to push on it.
Thank you everyone for the ideas. Dissent overnighted me Perry bumpstops to put on. Going to try those and mold the liner. Hopefully that fixes it so I don’t need to change the wheels to a +40 offset. The +25 looks great!
I know nothing about this Perry bumpstops, but will they impair your ability to off-road the truck and tuck the wheels when needed? If I were you, I would take their offer to switch the wheels and avoid the risk.
You can also tape it off when done and rattle can the area flat black, not really noticeable. Probably even go all the way around and just mask off the shiny outside portion.
Been doing this on my trucks for a long time. Small lift and stanced out wheels.
If you do that you can get more aggressive. Maybe even massage the damaged flare back in a little.
I like making unique setups work.
