Sorry about my poor description. On the front of the carb (facing radiator) there are four connections for vacuum lines. The connectors bring the vacuum lines to the front of the carb from the ports located on the engine side of the carb. The three to the left are for the EGR, dizzy advance and throttle positioner. Then there's the fourth, just to the right of the EGR, dizzy advance and TP (it's also slightly larger in diameter then the other three) and here's where I'm lost. The vacuum line from the top of this larger pipe goes to the nipple on the front of the air horn (got that much from the emissions manual) while vacuum hose that should go to the bottom....goes where? The hose that's stumped me would go from the brass colored nipple w/ out any vacuum tube in my photo. If I was better at Photoshop I could draw an arrow to it...but.
Thanks,
Ming
