Need help w/ 91 LC
Arkansas
My 91 got a sanding and buffing done at body shop today. When I got in to leave the shop, the A/T Oil Engine light came on along with the brake light. I drove home 2 miles and thought I would check things out. All fluids are at proper level, and since that trip, the lights are still on when I start it up. SOMETIMES. I 've got out four times since i brought it home and twice the lights were on, and twice they didn't come on?????
I am confused to say the least. Is there a way to see what is causing the warning lights to come on? Any help from you 3FE savy people will be apreciated.
Mark
Alternator or charging system.
Check cables and connections first. Since you just got it back from the shop I would be suspect of that.
If all is OK with connections and cable then your alternator has given up the ghost.
Yes, my money is on a bad alternator.
My advice is buy a high quality replacement.
I went through 3 in 2 years till I purchased a OEM Nippondenso.
That was 5 years ago and everything is 14.4 volts but I do carry a spare.
Maybe if I would of called CruiserDan the first time...
Good Luck:beer:
Thanks for the help/suggestions
I am checking connections now. The battery gauge reads 14+ but we will see.
Thanks,
Mark
Engine bay was not washed
The same ps fluid mess I had made a week before was still there. I thought of this too and was hoping.. oh well, good news I went to town this morning w/ no warning lights or other problems. NOw to find an alternator for spare/replace.
Mark
