need help! transfer case grind
Courtenay, vancouver island
its a 91import hdj80 6cyl with automatic trans, 4lo works but very bad sound in 4hi. my brother was winching and put it in reverse to try to pull out a truck and all of a sudden 4 high is fxxxed, still will move in 4hi but has half the traction and very bad grinding. think it might be the the center diff lock but im unfamiliar with the automatics and the 80 series. thanks for any input, cheers!
Sounds like a drive plate to me. Have a look at the front driveshaft in high range when the grinding happens. If it's spinning you have a stripped drive plate on one side of the other. Replace both and take a close look at the stub axle splines as they might be toast as well.
