Need help remove valve lifters
Mill Valley, CA
I also posted this in the 60-series forum, but since it involves a 3FE I thought I'd post here as well.
I need suggestions on how to remove the valve lifters on my 1989 3FE. I've got the rocker shaft assembly and push rod cover removed, but the lifters won't come out. The lifters move freely in the block, but when I try to pull them out I can't. This engine has 200K miles on it and there's a lot of varnish build up on everything. I suspect that there's a "lip" of varnish built up on the sides of the lifters where they stick down below the block casting that's preventing them from coming out. Any ideas? I could pull off the oil pan, but I don't think there's any way I'll be able to get to the bottom of the lifters with the camshaft in place, and I can't remove the cam with the lifters in. So I'm pretty baffled on how to proceed.
I have a KD tools #2079 Tappet tool that I use. I've never had a pushrod Toyota engine apart personally, so I don't know if it will work for your application. Small block Chevy's usually get treated to this tooks use though. Check your local Napa or old school parts house. I don't think that AutoZone or Checker/Schucks/Kragen would have something like that.
KD Air hold fittings, Tappet removers, Valve grinders
Dave
I had the same problem when disassembling my motor. I used lots of brake kleen on a rag to clean up that lip as best as possible. It worked for most of them but for the rest, I had to pull the camshaft and push them out.
" I have a KD tools #2079 Tappet tool that I use. I've never had a pushrod Toyota engine apart personally, so I don't know if it will work for your application. Small block Chevy's usually get treated to this tooks use though. Check your local Napa or old school parts house. I don't think that AutoZone or Checker/Schucks/Kragen would have something like that."
This may work but I have never tried it on a 3f-e
Pulling the cam was the consensus in the 60-series forum too. And to get the lifters out far enough so that the camshaft can be removed I either need to try Dave's slick tappet removal tool or go in from the bottom of the engine and drive the lifters up with a long punch. Combine this with tearing the front off the engine to access the cam and it becomes a good size project. :frown:
So I'm going to button it all back up and either wait until I have a whole lot more time available or take it to someone and pay $$$.
