Need Help!! OME Instl Great Except.....
Mukilteo
I busted one of the sway bar bracket bolts which attaches the bracket to the frame!!! I thought it was finally loosening up then "SNAP!!!" :crybaby:The bolt broke off in the threaded nut welded to the inside of the frame box. All other bolts after a thorough soaking of penatrant came out.
So I purchased a bolt extractor tool made of "High Carbon Alloy Steel" and proceed to drill a hole in the bolt as instructed, inserted the tool, and the unthinkable happened....."SNAP!!!!" :crybaby:the tool broke off in the hole in the bolt!!
After calming down I finished up the rest of the OME instl and I am now complete with the exception of this issue. Is there a drill that could make it through "High Carbon Alloy Steel"? The tool broke off internally to the hole drilled in the bolt so there is nothing to grab. I believe my only hope is to drill it out.
Any suggestions would be much appreciated.
Russell
I always have one of those multiple size, in case this happens to me. They work so great i just dril the frame and don't bother trying to remove the broken bolt.
http://www.spaenaur.ca/view_pdf.asp?Page=C168
Click next on the top of the page to see all type, and you will eventually get to the tools
I have a air gun but they also sell a special tool for them. But you can get them installed with a bolt the size of the insert and a larger nut.
The small tools
http://www.spaenaur.ca/view_pdf.asp?Page=C187
I would really like to remove the bolt, but this sound like a good alternative if all else fails.
we always do, and rarely succeed, well in my case.!
Now that you have the hardened extractor stuckin there thing will be a little tougher. On my broken bolts I ended up drilling and re tapping them. If you can get the extractor out drill the bolt and re tap.
Sorry I don't have any other brilliant ideas.
:cheers:
Every time this has happened to me I buy a high quality drill bit to drill out the bolt and try and re-tap to the same thread/size. That never works though and I end up drilling and tapping for the next size up. Next time I will not try and tap to the same size. It doesn't work.
Buy a bunch of drill bits, the "easy out" high carbon steel is tough to drill. After breaking a number of those things over the years, I now drill bolts and pound a torx 3/8 drive socket into the hole in the bolt. If it doesn't come out with that, its time to drill out the bolt and re tap the hole.
I had the exact same thing happen to me. I finally gave up on trying to get the bolt out and just tack welded the bracket to the frame - problem fixed. I figured it wasn't a component that I would eventually want to remove repeatedly, so welding was not such a big deal.
x2 Same here.
Just a tack weld and all is fine.
Good idea, I'll have to remember that...
I basically ended up spending the afternoon drilling out my last snapped bolt...
Patience, drill bits, and more patience....
I have a set of Bad Dog Drill bits and they seem to drill through anything. http://www.baddogtools.com/
Carbon steel can be drilled w/ a carbide or cobalt bit. You'll probably not find these at the local harware store - although our little Ace Hardware carries cobalt, but they have horse feed too so... Look on an industrial supply site like MSC Direct or McMaster-Carr. Go slow, add lubricant.
Wow, that really sucks. Might I suggest another approach. Another machinist at our shop was telling me about using his flame cutter to cut out broken studs out of nuts. There might be somebody in your local club that has one, or most welding shops would. Just a pop, and snap and it's out. Have something else ready to pop in it's place and tack it in and you're done. Course you could come to do this after breaking a cobalt drill bit, then trying to drill it now with a carbide bit, or just jump to this solution. Not the only way but a think it would be pretty quick and painless.
Bryan
After your reverse drill bit breaks (they are hard to find but the best thing to use).
Weld a nut onto the broken bolt........as soon as the red goes away, back it out.......works every time.
