need help installing gas pedal...........
City that rhymes with fun
im about to swap in a gas pedal and cable linkage from a 74 into my 67. it appears that there will have to be some modifications to mount it. it there an easy solution to this any info or pics would greatly help out. thanks friends.............
What year carb are you trying to attach it to?
BTW, 74s did not come with cable linkage, they came with rod linkage. Sooooo you may be dealing with an aftermarket setup already.
Hth
Mark A.
im putting a 72 2 bbl. sorry for the misquote of the year. it originally had rod linkage the nwas ghetto fabed to a cable setup for a 1 bbl rochester. its definetly a cruiser pedal assembly im putting in.
a 72 carb would run a cable with a trunnion on both ends. Your best bet is to use a cable and pedal from the same vintage, which will require drilling the full compliment of holes in the firewall to mount it.
Hth
Mark A.
thats what i figured and i have all the proper pieces. thanks mark for just helpin me make sure
