So I just came down to Mesa, AZ from St George, UT in my 80. It's a 7.5 hour trip and at about 3.5 hours into it, I started noticing an unusual vibration and after a couple minutes, I could tell it was getting worse. I pulled over and started shaking things and pulling things and couldn't find anything loose. I got back in the rig and drove around slowly and could hear something coming from the drivers rear, looked out the window at the rear tire and noticed it was wobbling ever so slightly. Hit the brakes and got out and checked out the rear tire. I could wobble it a bit by hand. Checked the lug-nuts and they were all loose! Crapola. Lucky I had all my tools in the rig. Got the socket and started crankin 'em down. Then on the second round to verify they were tight I broke one of the wheel studs. Suck. What sucks worse is there was already one busted off that side as I've kept putting off fixing it. Yes, in hindsight, I can see 20/20 on this. Anyway...
So I drove carefully and a bit slower than normal and made it to Mesa. I was planning on being here a couple days already but I could def use some help with fixing the rig back up to drive back home. Specifically, I need access to a FF rear bearing SST (or similar) and I'm gonna need access to a press or something to get the broken studs out and new studs in. I'm thinkin I'm gonna just replace all the studs on that side.
Oh and I'll be checking the local Toy dealers for new studs unless someone has any other suggestions on how to get them QUICKLY (don't really wanna pay overnight from C-Dan, but will if I have to...)
Anyway, I would really appreciate some help in the area. If you have any suggestions or can help, send me a message or post up.
Thanks!
-Ferg-
Thanks!
-Ferg-
