Need help finding something, if it exists.
I'm looking for a mountable USB port, like something I can put into a blank switch plate, and plug a USB cable from my nav unit into, while having an exposed jack for any USB device to plug into (i.e. a thumb drive, external HDD, that sorta thing).
Does something like this exists? I'm searching to no avail....
I'd ghetto-rig a small (4-port or less) external USB hub to fit. I've seen some really small ones that would have worked. I don't know if your a PC or Apple guy, but I've specifically seen a Apple USB hub that you could make work.
Worst cast scenario- you have to remove the casing off the USB hub and JB weld the port to the switch plate backing....
