need help diagnosing - air or fuel problem?
Hi - new member - I own a 1994 LC, and have been experiencing some engine stumbling around 2000 RPM. Today, I attempted to head up and go skiing, and found that the engine lost power across the rev range, to the point that I got off the highway. At the bottom of the exit ramp, the engine died.
I was able to restart after a couple of tries and made it back home. During the drive, I also noticed some clacking that wasn't present before.
No CEL, so I am planning on taking it in this week. Any ideas on where to start?
Thanks - Travis
Has the problem come on suddenly or gradually. A gradual increase in symptoms would point to something getting dirty over time, like an air filter. Or a gradual problem would be also indicate you need to tune it up. If you haven't tuned it up in a while, I would start will plugs, rotor and rotor cap first. If you can't remember changing the wires out, do those at the same time also. You can save yourself some coin by doing these things first in your driveway. Start with the simple stuff that you can do first before some "professional" gets in there and takes your money doing the same thing. Buy Toyota parts :hillbilly:
