Need Help. Birfield problems
OKLAHOMA cITY
So, I was about to work on rebuilding my Birfs.
And the other day, It seems like the bearing blew up. I started taking it apart and ran into a snag!
the center shaft, that the bearing go onto, has damaged threads. I was able to get the outer 52mm nut off, but it messed up the threads on the nut, the inner nut is still on, but if i take it off, there will be no way to get them back on.
So what can I do about the threads???
If the wheel bearing s*** the bed, there's a good chance the spindle is galled up. I'd source a new spindle before you start the birf replacement, then damaged threads are a non issue too.
You might be looking at a new spindle. Especially if you toasted a bearing...
You can easily replace the nuts, they're cheap. I would keep tearing it down and see how bad the bearing surface of the spindle is. If that's ok, you could possibly clean up the threads on the spindle with small files...
Probably looking at a new (or good used) spindle.
Anyone know what size, pitch the threads are? I figure I could see if I can fix the threads
I had messed up threads on one of my spindles (outer nut came loose, and spun around in there wearing all the threads away) Cruiser Outfitters had a new spindle in stock for me, so I replaced that when I did the knuckle rebuild. (along with new wheel bearings)
Just a word of caution... If you can "fix" the threads enough to get nuts back on doesn't mean they will still perform up to spec and keep the proper preload on the bearing. End result is that you could have additional problems and in the long term cost more in repairs down the road than would replacing the spindle now. There is also the safety factor to consider.
x2
If it was on a trail, I'd do what it took to "fix" it.
If it is in my garage, I will fix it correctly and I would buy a new spindle, new nuts, new bearings and seals.
But that's me.
I would also consider the TrailGear nuts.
