Need Help 401 Code
Sounds like the same as the first test shown here:
YouTube - 1FZ-FE EGR Valve Testing
Trying to think about this, but help me understand why, if the engine stumbles or dies, we have confirmed the blocked passageway?
EDIT: Also, how does this test confirm the EGR port is plugged ?
I have seen guys use this test to confirm the operation of the EGR valve. Remind me why the engine dies when we do this? What is actually happening?
the engine should die at idle if you do this because the egr valve is being fully opened 'manually' and is allowing too much exhaust back into the engine, causing it to stall.
Normally the egr system would gently 'modulate' the amount of exhaust being let in when you are driving so as not to overwhelm the engine, and the system is shut down completely at idle because the engine simply cannot handle any exhaust gases in this state.
The EGR system is simply a emisson control method to lower the Nox numbers on our vehicles by 'cooling' the combustion chamber gases....its a pain in the ass troublesome system, but we need it to pass our emissions testing and federal regulations.
yes...this is also the same test used to check if your egr valve is operational, but since he already replaced his we know that it is.
so if you manually open the egr valve at idle and it doesn't die the exhaust gases are not getting into the engine via the passageway through the intake....so it must be plugged.
That makes sense, as you said, based on the assumption the EGR valve is fully operational. I misunderstood a previous post.
If you think this system is silly, you should see the one on the FJ60s. That system was totally cobbled together to try and get a carb'ed engine to pass emissions. A total cluster f@ck. Got tired of all that and bought the 80-series !!
401 code DEFEATED!!!!!!!!!!!!! The port outlined in red was completely blocked. Thanks to everyone for there help!!! All it cost was 10.00 for a T-Body gasket. It passed emmissions and I have my tag. Thanks again. :-)
Great !!!
I am still of the opinion that this is the FIRST thing everyone should check when getting an EGR CEL. It's cheap to fix, and it happens very often.
Also think there is a misconception of which port this is when mentioned without any pics. I am sorry it has taken me so long to post one to clarify for folks.
I know you spent some money on the other EGR parts, but in the long run, you'll be glad you did. I'm betting you don't get a code for a long, long time !
Great !!!
I agree...and if it's not totally plugged up with carbon its probably partially plugged and should be cleaned out anyway.
Agreed! Mine was pretty nasty last year at 150k miles. It didn't fix the problem for me though so I ended up replacing the VSV and all the vacuum hoses for a complete fix.
Thanks for the pics...getting ready to do a decent sized tear into on mine. got cleaned injectors and plan on cleaning out all the little ports while i've got it apart.
That's the PERFECT time to do all this. Exactly when I did it. Had the injectors ultrasonically cleaned and the intake was all apart. While you are there, it's incredibly easy to replace all the heater hoses and the PHH. All new vacuum lines, do the VSV. Fuel filter too. It won't get any easier than now. Afterward, you'll start it up and it will run like a Swiss watch !!!
At least mine did.
Great !!!
No need to apologise. Looking back all the info was right there. I think subconsciencly I did not want to take off the t-body but everything works out for the best. No telling how many people this will help. Everyone should do this at least every 150,000. Mine was a mess and I cleaned everything. Looks like my gas mileage has gone up also. Thanks again!!! If you are ever in Atlanta let know I want to buy you a beer:-)
I honestly think that when the EGR system works as designed, it's not a bad thing. Problem is, most don't work as designed because they are full of carbon and most folks don't want to wrestle with getting it sorted out. Everyone wants a magic bullet, the one component that will fix it. Problem is, there are several components all with useful lives and all these trucks are old with lots of miles.
Get it back within spec, and "Bob's Your Uncle".
At least mine did.
yeah, i've got a huge list to do. already have a new vsv in there, but it's just zip tied to the brace, so i'll get it actually mounted. new f.f. is also ready to go on. phh was done before i got the rig. didn't get vacuum lines, but kind wishing i had. may see if my dealer's got some in stock.
If that PHH is over five years old, do it again, you'll be glad you did. The dealer doesnt' have the vacuum line, unless it's CDan, order yourself some, you'll be happier later !!
Sorry, but I'm one of those "do it right the first time" kind of guys. I HATE going into the same area again within a year to fix something I just had my hands on. Parts are relatively cheap compared to all the time investment.
