So I've been listening to this noise for only 2 years now, but , with my upcoming trip I've become more than a little curious as to what the hell it is. Not to mention its starting to irritate me on longer drives. So the truck makes a ticking noise that I thought was originally valve train noises. However, using the ultraguage I've noticed its not as much RPM dependent as it is throttle position. Here's the symptoms.
- happens between 2000-2400 RPM, it will not do it under acceleration, only while cruising, see below
- only happens when the TPS registers between 17 % - 21 %
Its definitely noticeable on highway drives once you've settled into final gear. Going up a hill at the prescribed RPM will not do it as you have to use too much throttle and it goes past the TPS values needed. Has anyone experienced this before ?
