Need exhaust advice
Vancouver (not BC), WA (not DC)
Hi everybody,
I need advice about exhaust. I have a stock 71 fj40. I still have the oem exhaust manifold that is in pretty decent shape attached to an F engine. However, the exhaust pipe back to the muffler is shot. I want to put on a whole new exhaust from the manifold back. My question is, should I go with the stock diameter or should I go larger? Would it benefit me to go larger since I still have the stock manifold? I don't really want to put on a header right now since my manifold does not leak and is in good/decent shape.
If I go larger, how large? I think the stock size is something like 1 7/8"? Should I go to a 2 1/4" or 2 1/2"?
Any advice is appreciated. Thanks!
Kyle
The more flow the better, especially with the stock header. 2 &1/4 will do the job if you get a high flow muffler.
yea i think that sounds good. just look at what ( dare i say it) jeeps run B/c they have almost the same size and style engine. Just looka at an engine like the same size as yours and ask people what they are running.
theres places that can fab up and bend an exaust exactly top your specs if you want and sometimes its cheaper!
good luck!
FF LC FREAK said:
Hi everybody,
Kyle
I do not think that you are going to feel any performance gains from going to a 2+" system...
Any decent exhaust shop will be able to fabricate a clean, complete system for you from the stock manifold back...I would have the shop doing the work make the system run above the skid plate, opposed to the stock location, below, so as to possibly prevent it from being damaged in the event you ever take your truck off road....
I would ask around/talk with other vehicle enthusiasts in your area as see if there is a local guy that people use for custom exhaust work. Who knows, he may be a 4x4 guy, like the one that I know...
Good luck!
-Steve
