Well, I'm not particularly that happy with the NAPA hub. Turns on/off when it should, but just doesn't move the volume of air when it's on that I'd like it to. Simply doesn't cut it for towing. Probably not even as good as my old one was running 50% with the broken spring and low fluid. After hunting around (in vain) for a used 2lte hub, I decided instead just to repair mine.
I removed the spring with broken piece and just had it laser welded here at UVic...haha...nice to have friends in high places. Going to re-install the spring, tig weld it to the valve shaft. I'll then re-adjust the turn-on temp of the spring (test in hot water), refill with 15000CST oil, and re-install to the truck. Should be a pretty kick ass fan after the tweaks.
I'll also have Cam's old fan hub tig-welded to eliminate the play at the spring/shaft.
