Need Electrical 101 Tips for Powerpoints etc.
Tierra y Libertad
OK,
My hands on experience on electrical knowledge is very limited. I can change lighting fixtures, fans, and put dimmers around my home, but when it comes to working around a car on electrical issues I am lost.
I need your help by advising me on the lay out and quantities of fuse blocks, etc. for what I am trying to do.
The Picture,
1. I'd like to install a 12V power point behind the center console like Paradise Cruiser did on a previous post.
2. I'd also like to install a 12V power point on the rear passenger quarter panel to power accessories at the rear (maybe a fridge in the not so far future.)
3. I am getting ready to install a CB radio in the ash tray. (I wanted to wait and just get CB radio and power points installed on the same day.)
4. I'd like to make a permanent location/install for my 12V air compressor somewhere inside on of the rear quarter panels.
How many fuse blocks do I need? 1 fuse block for each application?
Besides the proper gauge electrical wire, what else am I missing?
Q: do I go 8g wire from battery to fuse block and 10g from fuse block to power point?
Q: same example above for air compressor?
Thanks in advance.
the first thing you need to do is figure out what the amp draw will be for those items. You want the fuse for those lines to be high enough to support the load being placed on them but no so high that they won't blow in a reasonable time.
The compressor is easy as it should have a rating on it.
Once you know the amp draw you can then determine the wire size and fuse size.
Another thing is if they will be switched or on all the time. The one in the back for a fridge would most likely be on all the time but others wouldn't. Having the lines switched helps insure that if something is plugged in and left on it won't drain the battery.
Slee has a nice write up on putting a fuse block on the side of the rear heater under the passenger seat. You would run a fused main line to it and then branch out from there. You can get different configurations of fuse blocks as far as size and the amount of slots and the number of switched and unswitched slots.
the best thing to do is to draw out on paper where you want the sockets, swithed or not, amp rating and wire size to get things going. You can then work through any changes you might want and then install it.
Use this site for reference. It has lots of solid info.
http://www.bcae1.com/
What I would do is setup your power points with the maximum power potential. That means use 8AWG or even up to 4AWG wire to power them. When you do this you set the fuse on that wire based on WIRE SIZE. At those power points I would mount a good power distribution block which can be found at car audio supply stores. The fuse, of course, goes as close to the battery as is feasible. Then, you power each component off that distribution block and again choose the fuse based on the wire size you will use and place it near the distribution block. 18-12awg is enough for most things, larger for more power intensive things like air pumps and such.
Look over that link. Lots of good info there. cheers
One thing I have found is that I have added more and more things over the years. If I had built a solid power distribution system like what I describe above my rig would not weight 500lbs extra due to copper wire. Hehe.
If you run any radios on the same fuse block that you have the air compressor then you will get feedback when the compressor is running. Most air compressors will need a 30amp circuit; some as much as a 50amp circuit.
I agree with Landtank; draw up your plan and post it here and we will critique it for you. If you know absolutely nothing about 12v electronics then you can buy a book. I have and recommend "Managing 12 volts". You can get it on Amazon.
-B-
Thanks for the advice. How is this rudimentary schematic. If it is not good enough it is a sign that I may as well get a radio installer to do this http://images.ih8mud.com/images/smilies/tongue.gif
;p
"I would switch the line to the compressor because you'll want the engine running or it will drain the battery is a heart beat." How would I do that?
While you are under the center console you could use the ignition switched power from one of the unused plugs to power an inline relay for your compressor. How are you planning on operation the compressor? If you will just go back and switch it one when you need it, and if it is in a place where it can't be accidentally, switched on, then an unswitched power source would be fine.
Similar questions on the fridge.....
If you don't have a dual battery set up, you have the potential for a "no start" if you leave your fridge on all night, especially once you battery is a few years old. Are you planning on leaving it on all the time?
Good luck,
Dan
"the fuse blocks come with both switched and unswitched sections. The switched sections are only powered when the ignition switch is in the on position. It's not fool proof but one would hope that the engine is running." Thanks for clarifying.....
"How are you planning on operation the compressor? If you will just go back and switch it one when you need it, and if it is in a place where it can't be accidentally, switched on, then an unswitched power source would be fine." Dan, This set up you described is exactly how I want to fix my compressor to the rig.
In summary, I feel much better about how to go about laying out the set up....Now I can start buying what I need.
Also, for the switched port on the back of the console:
I would have that one powered with constant voltage. Here's why:
All of your intended plans for that port are for portable electronics. So, if your laptop is running low, you can plug it in and forget about it. It will charge whether you are in the car or not. Ditto for cell phones. As far as the DVD player goes, if it doesn't have a battery, it will stop playing when you shut the car off to get gas on trips. IMHO, better to let the kiddos keep watching while you are fueling.....
Here is mine BTW, constant power from somewhere........
I found that for this particular model of plug, (walmart) a 3/4 bit is a good starting point. Then you can trim the hole out farther little by little until it is just right.
A real fridge like ARB would be fine to leave on over night. I have one of those peltier coolers and that comes out at night because it has no low battery protection.
Low battery cutoffs are cool, I have that feature on my inverter, but I wouldn't want to have all of my food spoil due to low voltage.
A cheaper option than the ARB, or a dual battery setup is one of those jump packs. You could pack it along for emergencies and also plug the fridge into it at night, or just have it as peace of mind if your fridge does draw too much......
Make sure you use the correct sized wire to ensure no voltage drop - this will help you get more out of your battery without draining it so quickly and it will stop the fridge from turning itself of prematurely because it thinks your battery is low before it really is...
I would also make the run as direct from the battery as possible... the smallest wire will be the weakest link..
See the attached guide on sizing wires for the length of run etc..
