need confirmation on no start problem
1973 1973 FJ40
OK, rig was running fine before Xmas. I was remodeling the house and the rig sat for a month without running. I normally hook up a trickle charger to keep the battery fresh but forgot to being so busy and the CB killed the battery (it turns on automatically for national service warnings) and unless I pull the fuse, it will drain out.
Anyway, I wasn't too worried since I got a new jump starter from Costco. Jump started it and it ran fine. Parked it for a day and went to start it for a drive. Turned the key and nothing. Not even a click. I wiggled the positive battery terminal and it started up so I figured it was just loose.
Went for another drive tonight and same deal. Turn key, nothing, not even a click. I have full power in the rig: lights, radio, horn, all reading just under 12 volts. When I turn the key to ignition, I get a noticeable power drain and the volts drops down.
To get it started, I pulled the 12v wire from the ignition that connects to the starter (black and white) and just ran a jumper from the battery to the connector on the starter. Turned right over.
SO, what is the problem? What are the usual culprits. No power at the key switch or should I focus on the starter end. Starter works fine when jumped directly to battery.
Am I correct in that the ignition switch in the column runs one wire directly to the starter? If that is the case and I have power in the switch, I must have a bad or cut wire. in that case, maybe that was the culprit of the dead battery over the CB. Just to restate, I don't even here a click when turned to start. Just a drain in volts.
Thanks.
I am using the diagram from the tech links: http://www.geocities.com/calcide/fj40wd.html?20074
Just getting power to the switch does not mean that it is getting out of it....
Did you verify the operation of the switch and if so how did you do this?
I would bet that you have a loose connection...probably at the starter. ;)
Put the wire back on and see what happens....
If your batter cables can be 'wiggled', they are loose, and a loose connection at the battery is just asking for problems.
Tell me about it. They (bat. posts) are clamped down tight. I don't have juice at the starter wire that comes from the keyed switch, but power comming out of the keyed switch. I could only assume that the wire either frayed or snapped with age. I'll trace it tomorrow and test for voltage.
There should only be one white with black stripe wire runing into the starter from the key correct?
I had a similar problem turned out that my ignition switch was completey worn out. Got a new one and no problem since.
I am pressed for time (going back to work since vacation and remodeling the house) so until I have time to really fix it, I might just have to run a temp wire with a toggle to the starter until I have more than 10 minutes to work on it. I haven't even had a chance to look at it since the origional post. Probably the ignition as you suggest.
The starter solenoid wire from the key switch is a single black wire with a white stripe. White with black stripe is always a ground wire on Toyotas.
Sounds like your ignition switch is bad, but you may not have charged your battery up yet because you should not see a significant voltage drop when turning the key to "ign".
It could also be a bad connection of the fusible link or the big white wire at the battery + post. If the voltage at the chassis drops to near zero when you turn the key to "start" you have a bad connection somewhere in the circuit, probably at the fusible link.
If you are not even hearing a click, your solenoid is not getting enough signal voltage from the ignition key, or the solenoid is bad.
If you can take a small wire and run it from the batt to the solenoid and the truck starts then you know the solenoid is good (not sure if this is what you are doing or if you are bypassing the solenoid and giving power to the starter)
Check for a full 12V leading to your ignition switch, check all connections - be sure they are tight and clean and all fuses are good (do more than just a visual check)
Pull the signal wire (coming from your key) off the solenoid. Insert a volt meter probe here (on the wire). Put the black probe on ground. Turn the key, you should get 12V. If you don't you are not getting a signal from the keyswitch.
--> if you get a voltage less than 12V, but larger than 0V you have a bad connection or bad wire, or your ignition switch is bad.
If you do not get 12V, measure continuity from the solenoid wire to the ignition switch (cold side)
--> if you have continuity your problem lies with the switch or power to the switch, if you do not have continuity the problem is the wire.
If you have continuity on the wire to the solenoid, check for power entering the starter switch.
--> If you have power entering the switch, and continuity on the wire going to the starter, the switch is likely faulty. Put your + test lead on the output of the ignition switch, and your - lead on a known good ground. Turn the key. If you see 12V your switch is good, if not (and you have 12V on the input side of the switch) your switch is bad. (this is all done with the starter solenoid disconnected)
If you are at this point and you still have not found the problem, you likely had a bad connection, by which point you have likely taken apart. Put everything back together and it will work perfectly, to your amazement. (we hope)
Could someone tell me if I am missing some wires for the starter
One wire from the keyed switch (white with black I beleive) running from the column switch to the positive on the solenoid.
Thick ground running on the bottom of the starter motor to the frame.
Battery cable running from the battery to the positive on the motor?
Am I missing a ground on the solenoid?
I have power in my column when ignition is turned to start, but no starter, not even a click from the solenoid.
I can runa jumper from the battery positive to the solenoid positive and the starter turns over, but no start otherwise.
Just saw the above post. Thanks, I'll check later when I have time.
IIRC, on my 77 FJ40 the white with black is the ground. That shouldn't run to the positive on the solenoid. I'm working from memory here, so I could be wrong.
I finally got time to take a look at the issue this evening. Started with the simple test with a cheap power tester (the type that light up) and sure enough I had power going into the wire that runs through the igniton to the starter. I pulled out a wire brush and cleaned up the connections and put some electrical goop on it. Stuck the butt connector back on and clamped it tight with pliers. Turned right over.
Now why didn't that work when it was dark, 25 degrees outside, and I was running late for my clubs monthly meeting. I swear, those damn gremlins must have been pissed about something.
After having spent so much time on the cruiser and always having the worst happen because it is so old, I would have never assumed it was just a loose connection. I was ready to rewire the whole thing.
oh well. Maybe I am on a lucky streak. I'm going to go play super lotto.
