The basics: 73 FJ40, stock everything - except a 4" lift.
Problem was - very hard to start, running rich and loading up, black smoke from exhaust, died sometimes while driving; just basically ran bad.
Attempted remedies: had carb rebuilt, replaced plugs, wires dizzy cap, air filter. Installed Crane XR700 electronic ignition. Set the timing to the 'BB'.
Results: starts much easier, no more black smoke.
Problems: hesitates and lacks power on accelleration and climbing hills/mountains. Acts like vac advance isn't working, but checked the advance and it moves (sucked on the hose and the breaker plate moves).
Have the vacuum hose going from the advance unit to the fitting on the bottom of the carb. The only other vacuum hose goes from the dash pot (?) on the carb to a valve on the intake.
Does this truck have an advance or retard unit? Unit on the dizzy faces the firewall.
I'm at a total loss here by now. I've replaced both of the vacuum hoses with tighter fitting hoses thinking maybe vacuum leak - no change. NEED HELP PLEASE!
