need a new park brake switch
I got nailed for a safety inspection, I have spent many hours welding in new metal to make my 40 structural sound, all I need now is a few lights and a horn and the inspector should be happy, the only problem is I can't source a new park brake switch. They will fail me if the light does not come on when the park brake is applied, any ideas where to ge a new switch? noine at the dealer and our local aftermarket guys don't list them either. thanks.
my truck is a 75 with front drums. not sure which one I need, a bit reluctant to buy a used one, the internal spring fatigues as it sits compressed most of the time. thanks for the link.
located on Vancouver island, west coast Canada, its been a year since I have had her on the road, way too long.
Looks like the switch changed in 1976 model year (09/75), so if you do not have a 09/75 truck, you will need the earlier switch....
Good luck!
-Steve
just ran out to check the producation date on the vin tag, July 1975. How different can the park brake be? aren't they all drum brakes at the T case? my handle is just below the dash on the right side of the steering wheel. I guess I maight have to make one if they are not availible. Stupid inspection!
It's not the drum that actuates the switch; it's the arm behind the t-handle!
And they don't go bad all that often FWIW. I've tossed dozens of them cause NOBODY's EVER asked for one. If I find one laying around, and you can wait, you can have it. Might take a little while tho; kinda forgetful about this kinda stuff when I'm at the shop WORKING!:doh:
GL
Mark A.
FYI this is what the later parking brake handle and switch looks like (since I just happen to have one sitting here in the living room :)) Is it possible yours is just not hooked up or the bulb on the warning light is bad?
switch
another possibility is to just stick in a microswitch at some point on the mechanism where it will be triggered by the brake handle. would at least get you going until you get the right one, or would be a fine permanent solution if you aren't a purist.
(any momentary switch really)
microswitch:
m0y switch looks like the one in the pic too. I took the switch apart to see if I could fix it but no go. what year is the brake from in the pic?
