Need a harmonic balancer
Pensacola, Fl.
Who all offers Harmonic Balancer's?
I noticed when I tore my engine down the outer portion of the balancer spun some when the inner(bolt) didn't.
The dealer wants $280
I haven't taken the crank pulley off a 1FZ-FE, but from what I have read that sounds normal. The pulley isn't keyed on to the crankshaft. The 304 ftlbs on the bolt is what holds it in place IIRC. Hopefully someone who has done this can chime in.
Edit: the pulley is keyed ;) Thanks Onur.
Oops! :doh: Maybe I was thinking about the oil pump drive gear, or is it keyed too?
The pulley is indeed keyed into the crankshaft. It has a Woodruff key on the top of the crankshaft that the pulley fits onto.
Woodruff Key part #: 95161-30516
Crankshaft Pulley part #: 13470-66030
What happened was, I was "trying" to remove the crank bolt with my air gun. When I hit it ,the bolt never loosened or moved but the outer portion of the harmonic looked to spin the other direction?? :hhmm:
on your 96 the oil pump drive gear will spin freely if the crank bolt is loosened. You might want to post a pic so we all know what you are talking about.
I was trying to help answer the OP's question, but I managed to confuse myself in the process. I'll sit back down now... :o:D
