need 3rd mmbr tork specs
Hi, I'm new to this forum. I'm from the province of Québec in Canada. Tough this may sound heretic to your ears, I've put some fj40 diffs to my suzuki samurai. I bought the entire diff for 50$ because there was no brakes system and the ring gear/ pinion teeth were broken beyound usability because the previous owner had not settle backlash before use.
So, I just bought a used 4.11 r&p set marking compound and dial/magnetic backlash reader and I want to do the job correctly but I dont have the torque specs for the 3rd member. Would someone tell me these specs.
It's my firt time that I settle gears in a third member but I know I can do it. I will bring it to a diff shop after the fix to see if my job is done the right way.
Sorry for my english I'm french.
ObOne;
From the 1975 Chassis & Body manual, 98154, Page 13-12:
Diff Case ring gear 75.9-86.8 ft-lb
Diff carrier bearing cap 65.1-79.6 ft-lb
Drive pinion flange nut 144-173 ft-lb
and your english is fine.
Thanks,
Any other advice ...
Pinion preload
Bearing caps for settling the backlash
