Name this hose (help)
Washington
Looking for the part number for this hose or what people are using to replace it. I've been searching to no avail. Thanks in advance.
Looks like some 5/8" heater hose to me.
EDIT: And if that's your rig, I would be worried about more than just that hose, like that puddle.
I cant help you with the part number but if you ever wanted to delete the PAIR system now is a good time to do it and replace that hose with the straight through all metal verson that is found on the '95 models.
I did this and as a result i happen to have the old hose lying around which i can ship to you if you want it.
Jose B?
87245-60490?
Tis why I'm replacing it, coolant is leaking down it and pooling there.
The hose leading down towards the thermostat housing.
Did a quick search and I'm still not sure what a PAIR delete is.
That is the part number I thought, but I cannot find it anywhere I have looked.
I just had the same issue, and replaced it with a piece of 5/8" generic heater hose cut to fit. While it's not as pretty as the formed OE hose, it works perfectly and took care of the leak.
