Name that Vibration
Colorado
I recently picked up a '93 LC with 240,000 miles on it. I've got about 3 inches of total lift on it. It came with an harmonic vibration that starts around 60 mph. The vibration doesn't seem to change with engine speed, but will come and go at times. It's present much more than it's not. When I went from stock tires to 35's, harmonic was still there, but at different road speed which one would expect.
I pulled front drive shaft, it's still there.
Re-balanced front drive shaft (improperly put "in phase" during re-balance) vib was still present.
I checked the rear transfer case flange and rear pinion angles and they are identical.
I then had rear shaft balanced. It was "horribly out of balance" on the transfercase end from what the tech told me. He added about 1.5 oz to that end of the shaft. Vib was still present, but better.
I pulled the rear shaft tonight and vib is still present.
I'm pretty much left with engine, tranny or transfer case as the culprit.
What would be your guess?
Adam
I would think that you have not eliminated the diffs as a possible cause. Just because you took off a driveshaft, that wouldn't mean that the stuff inside of there would stop vibrating, 'cause they haven't stopped spinning!! Although, that might be a good test for me to try...and you might want to try the things mentioned in here...
https://forum.ih8mud.com/80-series-tech/338326-front-diff-roar.html#post5019777
Just to clarify, your front shaft has been balanced one time and during that balance process it was "in phase"? Or did you meant to say it was properly rebalanced while assembled properly out of phase and then reinstalled? If the latter, have you driven it with only the front shaft in? What provision to lock the center diff during this testing was made?
Also, describe the vibration - heard where, felt where? Is there a caster correction on the lift?
DougM
When the shaft was re-balanced, the tech commented that it was out of phase and he put it back in phase. This is before I read about the front shaft needing to be specifically out of phase. There was no change with the shaft in or out of the vehicle.
The sound is a sort of droning vibration with about a 1 second frequency. Frequency does not change with engine speed changes such as when I drop it out of overdrive.
I have a CDL switch that allows me to drive with either shaft removed.
I also have caster correction on the front axle.
The pinion and xfer case output are both solid with no discernible free play.
Tires/wheels also run true.
One theory that was offered up was an exhaust system harmonic. Maybe I shouldn't have thrown away the 5 lb paper weight that was bolted to the bottom of my 100 series.
Adam
That is enough lift that you may have problems with U-joint angle mismatch at the transfer and differential ends. If the frequency of the vibration is about 4X that of the wheel speed, then there is a good chance that it is drive shaft related. What are the angles at the ends of the drive shaft? It may be time for a DC shaft.
I measured both angles on the rear shaft and they are identical as they should be. Vibe is also there without the shaft in place.
I've removed everything possible and the vibe is still present. The only things left (I believe) are the tranny and xfercase and maybe the exhaust system.
Has anybody ever traced a vibe to those components?
Thanks,
Adam
Were the 35's you put on new, and were they the same rims or a totally separate set of rims and tires? Any idea if the front axle spindle bearings have grease?
DougM
How loud?
I guess you might have said how loud this sound was, I assume that at 60mph this is pretty loud. There are several things that caused my 80 to make noise. The idler pulley really pissed me off for some time, but it was present more throughout the range.
I've also noticed that my cat's are making noise now at speed. When I let of the gas the noise tends to drop out.
I have heard my fuel pump make a noise before, but I don't usually ride around with the radio on. That makes me more likely to hear all the noises.
I had to solve an issue on the roof rack where a piece had developed a whistle. That was fun.
Can you tell if the noise is in the front or rear of the vehicle?
As mentioned before - I wouldn't say you've eliminated the diffs yet. These are solid axles with full time 4wd. Unlike a part time system with locking hubs, these are always engaged. Could be gear noise from a dry diff? Easy check would be to remove the TOP fill screw and see where the level is at. I think the manual says even with the bottom of the threads. Somebody correct me here.
That's all I got. Do you have an Iphone that you could record the sound and host it somewhere?:beer:
I've baselined the vehicle so I think my diffs are O.K. I've torn down and rebuilt both ends with no change in the sound. All shafts checked out fine. It's not very loud, just an annoying low frequency harmonic, not that different from the vibes you experience in a small turboprop plane.
The exhaust on the vehicle is in pretty poor shape, so it could be there, but it doesn't change with RPM's. I'll play with letting off the gas and see if than makes any changes.
No roof rack and the fuel pump can barely be heard.
I've chased down vibes on other vehicles and usually find the culprit. This one has got me stumped.
Thanks,
Adam
