Name that sound! Clicking, chugging?
Lakewood, Ohio
My cruiser started running a little rough and was losing power / not easily accelerating past 45mph.
We went up a hill and it started this sound:
The sound is reproducible in 2 and L @3krpm. In D to really struggles around ~17krpm
Pulled over to give it a look and it was kinda chugging while idling:
Any change in oil pressure? Hate to say it, but that sounds an awful lot like a rod knock...
I bought my 93 and it had the same sound (seller disclosed the info and I paid accordingly)..,
Swapped titles, fueled up, made it 6 miles till the rod let go and punched a hole in the pan...
I wouldn't drive it if I were you, it's a lot cheaper to fix now than when it scatters...
One thing you could do it drain the oil into a clean container and see if you see metal fragments..
I always either run a magnetic drain plug or put a magnet on the bottom of the sump, then pull the magnet before draining, it keeps the metal on the bottom of the pan...
Good luck and I hope I'm wrong...
Thanks fellas.
I HOPE it's not terminal!
It's parked now.
If the cruiser is parked and I'm laying on the gas, there is no sound.
Hoping that's good news.
I'm taking it to a mechanic in the am.
Hold the brakes down tight, hit the gas a bit and take a listen. This replicates driving load.
