Name that Part- Real Time Help Needed
Bolingbrook
I'm finally getting to the grand reassembly of the dash of my 94; however, I have hit a speedbump. I don't want to keep going until this is resolved, lest I have to redo any more things. This part fell off of the support cross brace that is found inside the dash. Unfortunately, I can neither remember where it attached nor find a plug on the electrical umbilical that fits it. Anyone have any idea what this is and/or where it goes?
Thanks in advance to the Mud Collective.
Dan can probably ID if you post any part numbers or codes from it.
Possibly the starter-interrupt relay for the security system. Does it have a factory alarm?
I was going to say door/headlight buzzer but I don't know if these rigs even use them, I think mine only dings when the sunroof is left open?............but that looks like a buzzer not a dinger..........sorry no help.
I do have a factory alarm (08190-00850).
Also, the myster unit has the numbers 056700-8570 on it.
There are two other parts that I have since been able to locate mounting points for. The first is a black hook that I'm fairly certain is to hold the wiring umbilical in position, but I can't figure out where it goes.
The second is a plate that, according to the FSM, goes somewhere on the DS; however, I'm not sure where it attaches either. Also, in the picture it appears black because I rattle-canned it due to surface rust. From Mr. T it is silver.
Thanks,
-Sully
No idea on the exact location of the brackets. The catalog shows a piece that looks like the one in your LH photo in the general area of the left-hand side of the dash. The relay would mount in the left kick-panel area on an available tab that is within reach of the plug comming off of the alarm harness. The exact location would have been identified in the alarm installation instructions, which are long-gone.
The loop bracket probably attaches to some point of the instrument panel brace (the big tube-looking thingy) and would support the instrument panel wiring harness. Short of being present when the harness was removed it is difficult to guess the exact location.
The brace goes low on the DS and holds the plastic dash to the underside of the crossbar. The mystery box goes in almost the same location, still not sure its exact purpose. Not sure where that hook goes still. Man, 9 months is too long to wait between disassembly and reassembly.:doh:
Not that it will help, but Goggling that part number provides a single reference to a Nippondsenso "Accessory Relay" used in Toyotas, Accuras, and Hondas. Odd thing is that it identifies the Toyota application as 1988-1991.
