Mystery wiring harness clamp
I was hoping to find the part #'s for the No. 13 and No. 15 wiring harness clamps, but have not yet been able to.
Following the Waytekwire suggestion, the releasable clamps at the bottom of the webpage linked below appear to be functionally identical to the OEM part. Note the number on your Toyota clamp is the diameter in mm. So the No. 13 clamp holds a 1/2" wiring loom and you would choose your Waytek clamp accordingly.
Releasable Cable Clamps | Waytek Wire
BAAAAmmmmm!! 82711-3h180 Im working on other ones also. we all have broken up harnesses93 94 I prefer im factory trained certified lex toy an am good at getn parts even discontinued
I'm in need of 82711-3H180. How much including delivery to CA 90501?
Thank you.
Any body find 19 clamp part number slide on or 22 , (22 not used on land)
Did you ever find a part number for the 22? Looking for one. It holds the harness on the drivers side block in the middle. Thanks in advance!
