Mystery plugs
Austin
I was installing some new hood struts and noticed these three pluga in the very back corner by the passenger firewall. Two of them plug in to each other and clearly havent been plugged together in a loooong time. Any idea what they could be?
Is your trucked locked? If not, one is the orphaned front locker harness connection. If it is, it may not work. ;)
The 2 unplug connectors in the passenger side photo can't be for connecting the front axle diff locker. The front axle diff locker plug has more then 2 wires going to it.
I believe Mr T only made 1 harness for the 80. Therefore, in some markets they had diesels, some had block heaters, and so on. I could be wrong (happens often:flipoff2:) but I thought I read that somewhere.
Theres a third plug with no male connector side that is a 6 pin....that could be the locker I guess. The two that connect together are two pin...antenna may be?
If your talking about the plug in the upper left hand side of the photo, hidden behind the part of the harness with 2 red wires. Then yes, that very well could be the diff lock connector.
