Well this is probably a dumb question, but I've looked thru the
manuals and can't find the answer. Between the oil pan drain
plug and the transmission drain plug is a mystery pan. That is,
looking up at the drivetrain from the ground, you'll see a pan
between the two drain plugs.
What does it cover? What if any fluids are supposed to be in it? Mine has a
nasty hole in it. Should I replace it?
Thanks all. This is a 1972 FJ40, 3 speed.
