mystery leak
JayhawkFZJ80
95 Landcruiser, 226k miles, slowly baselining
Kansas
1 :banana: mechanic here.
so i got a medium size branch stuck under my 1995 LC. passenger side, after the 2nd cat. about where the exhaust pipe down moves over to meet the muffler.
could hear it dragging as i pulled away from my house. got out and pulled it out. didn't think anything of it.
i get to work and find a leak right about where i pulled the branch from. what is it? i didn't think there any lines containing liquid back there. what line is this and how do i fix it?
any help would be appreciated.
Video no worky but sounds like a rear heater line/hose is leaking. There are a couple hard lines and hoses in that area.
+1 rear heater lines. Sounds like it was a one in a million precision strike to get up in there.
i didn' t know the rear heater lines go that far back. going to look at a rear heater bypass. thanks for the confirmation guys.
Yep!
Those are DEFINITELY the rear heater lines. (The one under the front passenger seat) Yours are very rusty (like everyone in the MW) and the tree branch impacted them and cracked them.
Time to buy about 15-20 ft of 5/8" greenstripe Gates hoses and Breeze constant-tension hose clamps and do a bypass.
(Search "rear heater bypass") and do the bypass.
Since you have your cooling system drained, also change your PHH, check your heater valve on the firewall, and change any other hoses near the firewall and under the throttle body.
Refill with fresh clean green coolant mix (since you already have green in it).
Where in KS?
Yep!
Where in KS?
Thanks, Bilt4me. I've looked at videos, photos and read about the rear heater bypass. I'm sure I can do it. looks fairly straightforward. Went out and bought some green stripe Gates hose. i couldn't find the constant tension hose clamps is that a huge issue? I'm going to get regular clamps for the meantime to hold me over.
anything i need to be aware of related to any potential air in the system. I put green coolant in the reservoir right and not in the radiator?
I'm located in Topeka. There's a grand total of 3 other fzj80 I've seen here in the past year. only one is a great build, the others stock like mine.
You can use regular hose clamps (I have for years), but the Breeze brand are a constant tension and seem to do better on the hoses than the old standards. I have only found them over the internet, and I have -0- on my truck because I never have them when I need them.
Basically, be conscious of where you run the hoses, as they can and up directly above the cats. The cats run about 400°F-500°F, so there is significant heat around them when idling.
There are a few folks in the local club that are close. I see you have already posted in the introductions thread over in the club forum.
You may have seen me in Topeka a couple times, as I am there occasionally for work.
4x4Land in south Topeka can help with critical stuff that you feel is our of your league.
I have taken our 70 GMC K2500 as well as my Studebaker Lark to them and they have done excellent work. Jeeps are their bread and butter, but they do all makes.
If your coolant has a tinge of brown to it, i would recommend doing a flush on it with distilled water (basically fill it and drain it a few times with just distilled water).
Yes, you will have to "burp" the cooling system after doing this.
You will pour the coolant and distilled water into the top of the radiator to do your initial fill. Then start the truck and let it idle with the radiator cap OFF until it starts to overflow the radiator.
If you have questions about this, PM me and we can talk if needed.
The only way you would see me in Topeka...would be traveling through it. ;)
Lived there for a year. Ugggh!
I love the State of Kansas (lived in Independence almost 6 years) just don't care for Topeka.
Good to know there are Land Cruisers there though.
UPDATE:
so thanks for everyone's help. it was a harder than expected but then again everything is for a nube.
a couple of things that i learned:
PB Blaster is your friend. it helped with a lot of the rusted clamps.
also this thing below actually screws off. i keep trying to pull the pin thinking it would come out.
so now i've got it all done. the only question is did i burp it right. how do i know when all the air is out of the system? how do i replace an undetermined amount of coolant that i lost? what should inside the radiator look like when the car is running and i have all the air out and coolant is at the right level? any advice would be appreciated.
When the motor is cold remove the radiator cap. Fill the radiator up. Fire up the rig and let it run. When the engine warms the thermostat will open and coolant will circulate. Some air burps will blow out of the now open radiator. The coolant level in the radiator will move up and down. Top it off when it's not full, engine still running. When the coolant starts to overflow steady out of the top, put the cap back on. Put coolant in the overflow bottle, if there isn't already. Engine still running. You may see the temp. gauge go way up and then down again during this whole operation, especially in the beginning. This is the air circulating past the temp sensor. That's normal, keep an eye on it so you don't actually overheat. it should go back down in temp. after the air bubble passes.
Keep letting her run.
Monitor the level in the overflow bottle and adjust as needed. Let the it all cool off and check for leaks. Run it to the beer store and back then check for leaks.
It will be fine. The air will all come out.
Be
When its motor is cold remove the radiator cap. Fill the radiator up. Fire up the rig and let it run. When the engine warms the thermostat will open a d coolant will circulate. Some air burps will blow out if the open radiator. The coolant level in the radiator will move up and down. Top is off when it's not full, engine still running. When the coolant starts to overflow out if the top put the cap back on. Put coolant in the overflow bottle and let it run some more. You may see the temp. gauge go way up and then down again. This is the air circulating past the temp sensor.
Best explanation I've read so far period Thanks I'll do this as soon as I get a chance. Too many BBQs and beers that in my attention. Have a great Labor Day weekend and thanks again.
Great Labor Day to you and yours as well.
After reading my own post I corrected the worst of the grammar. It was as if it had been poorly translated from... I don't know..good luck man
