In the middle of tearing down my 6/76 china/OEM hydrid carb to clean it and I think I have some home brew tech that the PO added. There is the OEM phenolic carb spacer with the heat shield and then this mysterious spacer with mesh strainers/filters:
The text in the top says “TOP FRT” and “HC24 HC” I am almost certain it is the source of vacuum leaks that I am fighting and that it doesn’t belong. You can see that the hole pattern has been modified to fit. I can’t find any info online regarding a 2 barrel spacer/insulator/gasket with HC24. I see some Kohler gaskets with the center cut out like this, but nothing that is an exact match.
I am planning on tossing it in the trash unless someone can make sense of it before I do.
Thread about carb I am rebuilding:
The metal tag H3662 is the Aisan number for the 21100-61012 world carb and all the aftermarket Chi-carbs use that number. Looks like someone used the Air Horn from the old Aisan carb on the CCP replacement so they could hook up the fuel return line. The CCP 61012 carb wouldn't have that fitting.
Any late 2F kit should work fine. The gaskets are the same. Jets will differ depending on kit and if it even contains jets. Personally, I like the kits that have the leather plunger, which is actually more durable than the Viton when using ethanol-gas . It really takes two different...
