Mysterious Overheating
Shahram
I ain't got herpes no more.
TEHRANGELES
Went down to Baja this past weekend, in a little village about a hundred (mostly brutal dirt) miles south of San Felipe. Driving down a beach in 4LO, started to get bogged down in the soft sand, and I gassed it through. In little time, I was overheating, coolant boiling and puking out the overflow valve.
I stopped and let it cool down.
Mixed in some new coolant, filled it back up, turned back and limped it back to camp. No matter how hot the engine got, the fan didn't engage. I figured it was the fan clutch. Since I was a hundred miles from the nearest parts service, I figured I would just get it up to speed and hope that airflow would suffice. The next day, I put it back into 4HI and hit the brutal road back to San Felipe, hoping to find a part.
A few miles down the trail, my gauge was pinned at half-way, and I popped the hood only to notice that the fan was spinning as normal. The problem seemed to have fixed itself.
Does anyone know what the hell might have happened? What should I do? I don't feel comfortable getting back on the trail without addressing the issue, but I don't know where to begin.
Thanks for any and all advice.
What color is the fan clutch hub?
Sounds like a clutch with the fluid going bad and/or too thin, that how mine would operate before the fluid upgrade. How old is it, blue hub?
I believe it's OEM on a 96. It looks like a metallic color, and one side looks like someone marked it with a dab of blue paint. Don't know if that helps.
A natural metal base in a original clutch. It's time for a new one.
How hard of a replacement job is that?
I mean for a moron, not someone with actual skills.
One :banana: job you need to remove 3 belts and fan shroud.
I don't pull the belts. Remove the 4 nuts holding the clutch and the two top shroud bolts, pull the clutch loose, flex the top of the shroud back and remove the clutch between the shroud and radiator. Swap the fan to the new clutch and reinstall.
Also take a look at the condition of the radiator looking at the fins and in the filler neck. The fins on my rad were pretty corroded/rotten and the tubes had crud in them. All of it will seriously degrade cooling system performance.
This exactly what I just did...but be prepared to 'leverage' the alternator pulley cap back into position to get the first bolt started (start hardest of 4 bolts first to bring it back on-line / straight) as mine came slightly loose and 'torqued' over a bit from the belt tension. I used my hand to press the alt. pulley cap back enough for me to get the hardest bolt started first...then everything was just 'buttoning' it all back up. :cheers:
sharam,
just order a new fan clutch from dan. mine was similar and now it works great, a/c even works a tad cooler.
easy to remove-just undo the 4 bolts. i didnt remove the shroud or anything else and it was a quick job. if you have trouble, remove the shroud
